Odd misfire after engine swap
Long story short I blew up my previous motor and just threw a new one in with everything swapped over from old motor…same injectors same dizzy same harness and now I have misfire at idle and low rpm higher load situations compression is good and mechanical timing is good no clue what the issue would be being the same set up worked fine on the previous motor
