OBX LSD install
im about to install my obx lsd into my d16z6 tranny and was wondering if there is anything i should order new from honda and replace while i have it open? and also is there any kind of write up for installing this lsd into a z6 tranny? i already know once i get the lsd i should tear it down and "rebuild" it.
thanks
thanks
Your going to need the following parts to do it right. if i remember correctly its about $140 in parts
41312-PL3-B00 speedo gear
91005-PS1-003 Diff bearing (need 2)
91002-PSO-003 ISB bearing
91216-PL3-005 ISB seal
23927-PL3-000 thrust washer
23928-PL3-000 thrust washer
Just take your time and make sure you get your clearences right and everything torqued to spec.
platinum.
platinum.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 »</TD></TR><TR><TD CLASS="quote">Your going to need the following parts to do it right. if i remember correctly its about $140 in parts
platinum.</TD></TR></TABLE>
ive never taken a tranny apart so dont know anything about it.. but the helms or haynes manual sjhould be all i need to know? are there any tricks or things i should know about when putting in a lsd.. i read somewhere something about shimming something??
if you have not done it before, i would take it somewhere and watch them do it for the 1st time. the tranny can get kinda confusing.
Mistabone on here did mine for me.
platinum.
platinum.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 »</TD></TR><TR><TD CLASS="quote">if you have not done it before, i would take it somewhere and watch them do it for the 1st time. the tranny can get kinda confusing.
i live in bumfuck usa, no can do, i dont trust anyone in the state of missouri.
there is no need to buy those bearings when changing a OBX in. you'll end up potentially causing more damage that way. than if you just made sure the bearings are in good condition BEFORE installing the OBX.
you need a press them on and off which can be screwed up by even good tranny guy.
as long as the trans has no grinds the only thing gnna hang up up is getting the clearances per the manual, since there is sometimes an issues with the diff bearing clearnces.
i think Mista Bone recommended using a b-series oil control ring to shim it. i just took my time and actually ground my stocker tp spec and till last weekend the car hasn't had any tranny problems
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NastyHabitzCRX »</TD></TR><TR><TD CLASS="quote">there is no need to buy those bearings when changing a OBX in. you'll end up potentially causing more damage that way. than if you just made sure the bearings are in good condition BEFORE installing the OBX.
so i need everything else besides the bearings? still dont understand about this shim thing? what is being shimmed and how much do you shim it?
but yea the tranny that its being put into is in perfect condition.
</TD></TR></TABLE>so i need everything else besides the bearings? still dont understand about this shim thing? what is being shimmed and how much do you shim it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93boost »</TD></TR><TR><TD CLASS="quote">
i live in bumfuck usa, no can do, i dont trust anyone in the state of missouri.</TD></TR></TABLE>
Holla
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSi »</TD></TR><TR><TD CLASS="quote">Helms will help you out. </TD></TR></TABLE>
But not Haynes ... I am 99% sure under trans my haynes manual talks about removal to take it to a qualified tech etc
no internal info.
I found a useful post on shimming and what not on here once, I'll try to find it again ... seems like it was about the installation of an ITR LSD ...
Holla
no internal info.I found a useful post on shimming and what not on here once, I'll try to find it again ... seems like it was about the installation of an ITR LSD ...
platinum.
Damn you actually need to replace all that stuff? Even on a good tranny?
platinum.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 »</TD></TR><TR><TD CLASS="quote">Damn you actually need to replace all that stuff? Even on a good tranny?</TD></TR></TABLE>
I would only replace bearings that sound bad...
i think Mista Bone recommended using a b-series oil control ring to shim it. i just took my time and actually ground my stocker tp spec and till last weekend the car hasn't had any tranny problems </TD></TR></TABLE>
your not going to cause damage if you know what your doing.
im sure you could take some shortcut and not get some of the items listed, but for $140 bucks why not have brand new parts all the way around.
platinum.
platinum.
Where do you live?
Where do you live?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wleach11 »</TD></TR><TR><TD CLASS="quote">
Where do you live?</TD></TR></TABLE>
It says Columbus Ohio right underneath his post count.
when i did my LSD install i replaced all my syncros cause they were junk.. just be very careful around the barings not to ding them and stuff and tourque everything down... i went right to my honda dealership and they printed off a detailed paper for me of the gears and stuff that had all the TQ specs... good luck man.. just keep it clean.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bch5428 »</TD></TR><TR><TD CLASS="quote">yikes i didnt change the speedo gear.. did you recommend changing due to maintainence? i got new bearings and shimmed the dude up with an oil ring and everything worked pretty well.</TD></TR></TABLE>
you used a piston oil ring right? I might try that.
the speedo gear is is not required to change, unless its broken.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wleach11 »</TD></TR><TR><TD CLASS="quote">No it says Missouri under his post count. Trying to figure out where in Missouri.</TD></TR></TABLE>
You quoted platinum00 and it says Columbus Ohio under his post count. Maybe you quoted the wrong person.
platinum.</TD></TR></TABLE>why disassemble a pefectly good set of bearings when there is nothing wrong with them? just because it's cheap doesn't mean it's always nessecary.
the extra work involved and cash is not worth it when the tranny is good to begin with
holts summit, mo...its 2 miles from jefferson city.
i still dont understand shimming. or what exact new oem parts i should get..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NastyHabitzCRX »</TD></TR><TR><TD CLASS="quote">why disassemble a pefectly good set of bearings when there is nothing wrong with them? just because it's cheap doesn't mean it's always nessecary.
the extra work involved and cash is not worth it when the tranny is good to begin with</TD></TR></TABLE>
everyone does things differently... you do it your way, and ill do it mine.
platinum.
platinum.
platinum.</TD></TR></TABLE>great as long as we agree then, don't pretend that personal opinions are not solid fact
