OBD2 Boost inspection?
Old Nov 25, 2007 | 08:52 PM
98ej8coupe's Avatar
Default OBD2 Boost inspection?
I plan on boosting my 98 coupe this spring and was gonna run a chipped obd1 ecu with a jumper from obd2 and have a cat and a o2 bung on the down pipe..when it comes to inspection time i wanted to put my obd2 ecu in just for the inspection...now my question is does anyone know if i will throw any codes as long as i have a primary and secondary o2 sensor? thanks in advance
Old Nov 26, 2007 | 02:17 AM
speedycrx's Avatar
Default Re: OBD2 Boost inspection? (98ej8coupe)
it souldn't throw a P0420 code (cat effieciency) but i'm not sure the oem computer will like the boost. so i would turn the controller all the way down.
Old Nov 26, 2007 | 02:52 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: OBD2 Boost inspection? (speedycrx)
if you change injectors for the obd1 ecu, you will need to change them back too.
Old Nov 26, 2007 | 03:30 AM
98ej8coupe's Avatar
Default Re: OBD2 Boost inspection? (boostedcivicsir)
i plan on running 10-12 psi so that means i need to get a 3bar map will this throw a code also?
Old Nov 26, 2007 | 09:05 AM
quicksilver1689's Avatar
i ♥ snails
you could always put a resistor on the O2 sensor. The obd2 ecu wont like the 3bar map, it wants to see what its programmed to see, anything else it doesnt know what to do so it trips the code.
Old Nov 26, 2007 | 09:14 AM
mrbigg9032's Avatar
I plan on doing the same thing this spring, and im also from ny. Now if ur running larger injectors then ur going to have to swap ur stock injectors back in, with ur stock ECU. Ur going to have to have 3 out of 4 readyness codes ready which wont be because u just took out ur ECU. Your going to have to drive around for about 10-20 miles to get the codes ready in order to pass. During this time have both O2's plugged in and stay the hell out of boost. ( lower boost as much as possible, take out wastegate spring whatever does the job)
Old Nov 26, 2007 | 09:50 AM
BoostinEJ1's Avatar
Default Re: (mrbigg9032)
what codes will it throw?
Old Nov 26, 2007 | 10:23 AM
mrbigg9032's Avatar
It shouldnt throw any codes if u have both O2's, stock map, stay out of boost, and have a good cat... I mean is ur car had a code before u boosted it or it wasnt running right then dont expect for that code to magicaly disappear because u took the turbo off. Just double check before u go to get it inspected. I would also recommend getting a code scanner which tells you what readyness codes are ready. I have a actron scanner and there well worth it. So u dont end up going there and only 2 out of the 4 r ready of something stupid like that happens and u fail.
Old Nov 26, 2007 | 11:14 AM
BoostinEJ1's Avatar
yeah theres nothing wrong with it now its pretty much stock and i have no codes so hopefully ill be good.
Old Nov 26, 2007 | 11:16 AM
98ej8coupe's Avatar
Default Re: (BoostinEJ1)
sorry posted on a friends name again
Old Nov 26, 2007 | 01:58 PM
Tippyman's Avatar
Ever thought of yanking the CEL bulb?
Old Nov 26, 2007 | 02:40 PM
98ej8coupe's Avatar
Default Re: OBD2 Boost inspection? (Tippyman)
would be good but the car is a 98 and in ny it has to be plugged in to the computer
Old Nov 26, 2007 | 03:31 PM
saxqtzk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">Ever thought of yanking the CEL bulb? </TD></TR></TABLE>
You'll fool only a visual inspection, but like stated above the car will be plugged in and information will be sent from your car to the inspection computer and if the vehicle has any codes it's an automatic failure.
In NY, OBD1 vehicles are tested on the rollers. OBD2 cars are plugged in.
http://www.amazon.com/Actron-C...r=8-3
I Purchased this OBD2 scanner, checks IM readiness and deletes codes.
Old Nov 26, 2007 | 03:48 PM
m R g S r's Avatar
my friend has a new inspection guy......sends him a copy of the reg and $100 and a sticker is sent back.....don't know how, but it works lol so look around im sure it can be done, worth the $100 a year instead of going through all that trouble
Old Nov 26, 2007 | 03:54 PM
B18C_EJ8's Avatar
Default Re: OBD2 Boost inspection? (saxqtzk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saxqtzk &raquo;</TD></TR><TR><TD CLASS="quote">
In NY, OBD1 vehicles are tested on the rollers. </TD></TR></TABLE>
Um, no they're not...
Old Nov 26, 2007 | 03:55 PM
B18C_EJ8's Avatar
Default Re: OBD2 Boost inspection? (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">my friend has a new inspection guy......sends him a copy of the reg and $100 and a sticker is sent back.....don't know how, but it works lol so look around im sure it can be done, worth the $100 a year instead of going through all that trouble</TD></TR></TABLE>
It can be done for $42 a year...
Old Nov 26, 2007 | 04:32 PM
borat's Avatar
Not to mention the CEL not coming on briefly when the key is turned on is a failure in itself.
Old Nov 26, 2007 | 05:31 PM
saxqtzk's Avatar
Default Re: OBD2 Boost inspection? (B18C_EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">
Um, no they're not... </TD></TR></TABLE>
So how is it tested? I guess it's just the city then.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by www.nysdmv.com &raquo;</TD></TR><TR><TD CLASS="quote">
A 1995 or older model year vehicle, or a vehicle that weighs 8,501 lbs. or more is required to have a high-enhanced emissions inspection if the vehicle:
-Is registered in the New York City Metropolitan Area (NYCMA), and
-Is not exempt from emissions inspection.
Vehicles that have a model year of 1981 or newer and a weight of 8,500 lbs. or less must receive a dynamometer test.
Old Nov 26, 2007 | 05:42 PM
B18C_EJ8's Avatar
No inspection stations anywhere around here have anything resembling dynamometer testing... :shrugs:
tpdc2
Sep 6, 2007 10:21 AM
stratedrm
Jun 28, 2007 02:12 PM
tegman85
Jun 3, 2007 04:10 PM
Ty.
Mar 27, 2003 05:48 PM
paulyman
Aug 26, 2002 04:40 PM
