o2 sim hookup question
Old Feb 20, 2004 | 05:43 PM
ATS*Mark's Avatar
OG triple OG
Default o2 sim hookup question
i bought the egc o2 simulator , how do i get it to work without the secondary o2??? thanks
Old Feb 20, 2004 | 07:01 PM
zip's Avatar
zip
Default Re: o2 sim hookup question (Hella_JDM)
As written in the instructions, with the O2SIM installed place a 1K resistor between the two black heater wires to prevent a heater code when the O2 sensor is completely removed.
Old Feb 21, 2004 | 12:20 AM
TravSi's Avatar
Default Re: o2 sim hookup question (zip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zip &raquo;</TD></TR><TR><TD CLASS="quote">As written in the instructions, with the O2SIM installed place a 1K resistor between the two black heater wires to prevent a heater code when the O2 sensor is completely removed. </TD></TR></TABLE>
Amazing instructions tell you how to do stuff, I thought they were just to make you feel bad if ya cant read....I would never have guessed?
Old Feb 21, 2004 | 01:10 AM
ATS*Mark's Avatar
OG triple OG
Default Re: o2 sim hookup question (TravSi)
i realize that... so it will throw a heater code not a secondary o2 failure correct?????
Old Feb 21, 2004 | 05:52 AM
platinum00's Avatar
if the sensor is build right it wont throw any codes.
platinum.
Old Feb 21, 2004 | 08:00 AM
genop's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">i realize that... so it will throw a heater code not a secondary o2 failure correct?????</TD></TR></TABLE>
If you put the resistor in between the two black wires and you have the simulator hooked up correctly you shouldnt throw any codes. If you remove the sensor and dont put the resistor in then yes, you will throw a o2 heater failure code.
traxxasx
Apr 16, 2008 06:34 AM
kcrxxx
Aug 13, 2007 05:10 PM
Mini-mEK4
May 10, 2004 11:05 PM
fast[R]
Apr 24, 2002 04:58 PM
99CivicSi
Apr 22, 2002 04:27 PM
