O2 sensors - Bosch doesn't work, OEM is $$$, What about Denso?
From experience I've found that Bosch O2 sensors don't run well when used with a Honda ECU. The OEM ones are the only sensors I've ever used consistantly, as they work great. Problem is that they're expensive as hell.
Has anyone used the Denso sensors yet?
Or any other options other than OEM or Bosch?
A search yeilded nothing worthwhile, so I guess this is new territory.
Re: O2 sensors - Bosch doesn't work, OEM is $$$, What about Denso? (hypa)
i dont know what your talkin about. i have a bosch o2 on my 2nd o2 spot and i havent had any problems. did you wire it correctly????? it took me 2 times to figure out the color coding other then that????
Re: O2 sensors - Bosch doesn't work, OEM is $$$, What about Denso? (envision2teg)
wondersparrow
05-02-2008 07:28 AM
