O2 sensor problem
Old Oct 16, 2006 | 05:25 PM
loopedR6's Avatar
Default O2 sensor problem
ok well i finally got my downpipe welded back together and reinstalled the O2 sensor. however, after resetting my ecu, as soon as my car started to boost the CEL came back on. i checked it and sure enough, 41. so could it be that because im running an FMU (yeah i know they suck, =death, will blow up my motor, etc.;please i dont want this to turn into a lecture on why i should not be using an FMU, ive had plenty of those already and it will be replaced soon) that its making my A/F ratio way too rich and thats why im throwing a O2 sensor code?
Old Oct 16, 2006 | 06:03 PM
platinum00's Avatar
Default Re: O2 sensor problem (loopedR6)
02 sensors go bad often. you could just have a bad sensor. there cheap, i would replace and see what happens.
if your running a FMU it only adds fuel under boost, so if your throwing the CEL when starting the car i would say you have other problems. remove the FMU (for testing) and see what happens.
if you have access to a wideband, hook it up and see what your A/F is
platinum.
Old Oct 16, 2006 | 06:31 PM
loopedR6's Avatar
Default Re: O2 sensor problem (platinum00)
the O2 CEL only came on once i hit boost. when i started the car and before i hit boost i was good and had no codes pop up.
Old Oct 16, 2006 | 06:35 PM
siblues's Avatar
I was having the same problem when i was running my drag kit with the fmu?I replaced the o2 sensor twice and it always came back?
Old Oct 16, 2006 | 06:44 PM
loopedR6's Avatar
Default Re: O2 sensor problem (siblues)
did you ever get it fixed? if so how did you do it?
Old Oct 16, 2006 | 06:46 PM
siblues's Avatar
I never could get the cel to stay gone.I ended up doing a full build with an ems before i could figure it out?Sorry but i was also thinking the same thing regarding the rich mixture.
Old Oct 16, 2006 | 08:10 PM
loopedR6's Avatar
thanx for the help anyway
wintermute
Sep 6, 2010 02:11 PM
project91crxsi
41
Oct 30, 2009 04:56 PM
2008fijibluesi
Honda Civic (2006 - 2015)
Mar 27, 2009 06:23 AM
sackdz
Nov 4, 2003 06:40 PM
