O2 sensor help...
Car-94 Ex Accord with VAFC and 440cc bluetops Tial 38mm Gate on a 60/63 trim turbo with 7.5lbs of boost...
I am under the impression that the O2 sensor is causing the car to be flooded with extra fuel after a few hard runs as the heat starts to saturate the exhaust piping and undoubtably the O2 sensor.
?Could I distance the O2 sensor from the pipe with a bung spacer(use a spark plug defouler and dremel it out to distance it from the pipe)?
