o2 sensor
Old Sep 9, 2013 | 10:45 AM
duf2570's Avatar
Default o2 sensor
so there are 2 sensors on my downpipe a o2 sensor and the wideband sensor,,,,my question is could it be a bad o2 sensor that can cause a rich idle problem????...im obd1 and dont have check engine light....
Old Sep 9, 2013 | 10:50 AM
turbohatch96y7's Avatar
Default Re: o2 sensor
I have no idea what you just typed. Read it back to yourself and re type it.
Old Sep 9, 2013 | 11:12 AM
grumblemarc's Avatar
The Grumpiest
WTF did you say?
Old Sep 9, 2013 | 12:20 PM
duf2570's Avatar
Originally Posted by grumblemarc
WTF did you say?
washh.. stupid auto correct English cellular
edit
Old Sep 9, 2013 | 03:16 PM
The Grumpiest
Not enough info.
Old Sep 9, 2013 | 03:47 PM
duf2570's Avatar
Not enough info.
For about 5 days ive got a rich idle after my engine is warmup (12-13afr vs 14-15)so ive changed my sparks plug/wires regapped, fuel pressure is 51psi at 1000rpm(idle)...the car run great.wot afr is good ..dont know where to investigatetuned on chrome gold
Old Sep 9, 2013 | 04:00 PM
TheShodan's Avatar
Moderator
https://honda-tech.com/forums/forced-induction-16/changed-plugs-now-rich-iddle-3168787/
We get it... But I guess what we're figuring out is the type of 02 sensor you're using. the OEM won't read the same in open loop as say a wideband. The Narrow band sensors aren't that accurate to read in lambda so you may be creating an issue that doesn't exist. that's why you're not getting a lot of responses here.
Keep one thread, trash the other... no need for 2 threads
Old Sep 9, 2013 | 05:03 PM
duf2570's Avatar
Originally Posted by TheShodan
https://honda-tech.com/forums/showthread.php?t=3168787
yes i know...sorry ive tried to earase the thread but dont realy know how to...
Old Sep 9, 2013 | 10:15 PM
CO_RaceFab's Avatar
if the ecu is set in open loop than its not the o2 causing this but if its in closed loop it very well could be the sensor as the sensor doesn't just send out 0v when they go bad. usually they read 14.7 a/f when they go bad so in your case if your ecu is seeing 14.7 a/f it will try to correct it.
Old Sep 12, 2013 | 01:55 PM
duf2570's Avatar
i found that im in open loop..so i will change the cap rotor and rotor..i will see..weird issue..dont think that my problem come from the iacv valve...my iddle is steady...
Old Sep 13, 2013 | 11:07 AM
duf2570's Avatar
just talked to my tunner today...and he said that my tune is a little off due the colder temps outside....curious but plausible????
Old Sep 13, 2013 | 02:42 PM
wantboost's Avatar
Who is Mr Robot?
So which sensor is the ecu wired to? You should really have the 0-5v wire from your wideband hooked to your ecu for proper fuel control. The stock narrowband sensor is worthless. Get rid of it altogether and plug the extra o2 bung
You're obd1 so you'll never have to hook a 0-1v sensor back up to your ecu like us obd2 guys have to do come emissions time
Colder weather? Where the hell are you? It's still 90+ here in Georgia FML. I mean the ecu will compensate for barometric pressure and temperature so variances in fuel trims are to be expected but it shouldn't swing wildly in either direction from where your inital tune was done in terms of air/fuel ratios
Old Sep 13, 2013 | 03:46 PM
duf2570's Avatar
i just remove the old o2 sensor that was used with the narrowshitband,,this one was only for the narrow gauge not plugued on the ecm my mistake ive tinked it was,,,now i only have the innovate wideband sensor.. now here in quebec/canada the temps are above 50-60f days..and i was tunned at 75-80f...but im still not sure about the afr variance...but my tunner(a good one) said that the outside temp cause my rich idle after engine warmup(12,5 to 13,5 afr vs 14,5 to 16) and cruise(cruise is close to normal) the begin/mid and full wot is perfect..i just told him all the fact/things that i have look the sure that my issue doesnt come from fuel pressure/ignition/plugs/etc..and he 100% affirmative about the outside temps
Old Sep 13, 2013 | 05:23 PM
wantboost's Avatar
Who is Mr Robot?
So the ecu is receiving a 0-5v signal from the widebands output? Verify this is the case
Do you have a laptop where you can plug into the ecu and datalog? If so datalog o2 voltage to see if it's got a 0-1v or 0-5v signal. Having the narrowband connected to the tuned ecu will cause all sorts of issues since it isn't accurate by any means and is slow to respond. You NEED to have the 0-5v output from the wideband run to the o2 signal pin on the ecu. This is the only way for the ecu to accurately measure air/fuel ratios and self adjust accordingly
Cold weather will yield a slightly richer idle and it might cause the whole map to go slightly rich
What airfuel are you getting under wot?
Old Sep 13, 2013 | 06:19 PM
duf2570's Avatar
no i dont have the hardware(tuned on chrome gold) to datalog...and the setup is tuned on a p28,,, there are no o2 sensor on my setup connected to the ecu..the wideband sensor is only hooked to the gauge.now as i can understand there are nothing(sensor) who can tell to the ecu what temp is outside???..i will look at the old narrowband connection if there are any kind of signal...and follow the right way to connect my actual wideband sensor to the ecm
im at 11,6-11.9 wot afr..on 91 octane/ 50/50 meth injection now at 12.2-12.6
Old Sep 13, 2013 | 09:15 PM
CO_RaceFab's Avatar
uh colder weather will make the car go lean... I tune year round in Colorado weather and I have to adjust stuff on all of them all the time unless the car is setup right and runs in closed loop.
Old Sep 14, 2013 | 09:17 AM
duf2570's Avatar
im in open loop...and again my mistake...i run leaner on wot condition EDIT!!!..I drop the boost one ''clic''on my mbc to be safe
Old Sep 15, 2013 | 10:53 PM
CO_RaceFab's Avatar
I wasn't correcting you I was referring to this post.
Old Sep 17, 2013 | 11:12 AM
wantboost's Avatar
Who is Mr Robot?
That is true. My bad
I forgot to ask if he was running open or closed loop
honda.lioness
Engine Management and Tuning
Feb 27, 2009 09:12 AM
jayman3.0
Feb 3, 2008 05:07 PM
youngvedder
Oct 24, 2004 12:42 PM
