o2 + boost?
Old Aug 8, 2003 | 08:08 PM
5STAR3's Avatar
Default o2 + boost?
i need to re-wire my o2 sensor and i am getting ready to put on a turbo pretty soon. will the fact that my o2 sensor is not functioning correctly be bad for the boost. do i need to get the o2 wired up before i can put the turbo on.
i do plan on fixing the o2 sensor it is just not as high priority as other things right now.... unless it needs to be.
Old Aug 8, 2003 | 09:13 PM
redteg87's Avatar
Default Re: o2 + boost? (envision2teg)
Um. Let's start with this:
N/A + Bad O2 sensor = Poor performance
F/I + Bad O2 sensor = Dead engine
Tuning is hard enough with a good O2 reading. You'll just be egging the detonation fairy on without good engine management.
Old Aug 8, 2003 | 10:16 PM
5STAR3's Avatar
Default Re: o2 + boost? (redteg87)
yea....
i better get on that.....
Old Aug 10, 2003 | 10:10 AM
Pengo's Avatar
yea make sure everything is perfect n/a before you boost. don't rush into boost if somethings even slightly wrong. better to have imperfect n/a motor that you can at least drive around for now instead of a boosted motor that goes nowhere
aojtin
Jul 9, 2008 01:40 PM
motormike40
Oct 22, 2006 03:54 PM
WhoNeedsVtec
Feb 25, 2003 11:29 PM
