o-ring reciever groove in the head???? help
Old Jan 23, 2003 | 04:55 PM
turboex's Avatar
Default o-ring reciever groove in the head???? help
I looks like im gonna have to use a steal o-ring and a copper head gasket. The groove is there for the copper rings will i need a reciever groove in the head also? larry at edyne and summit racing say i do. any ideas?
Old Jan 23, 2003 | 05:27 PM
rudysfastone's Avatar
Default Re: o-ring reciever groove in the head???? help (turboex)
The only way you can seal a copper gasket right is to use a safety wire in the grooves and machine a receiver groove in the head so the copper can push into it. If you're talking to larry, he can give you the specs necessary for the receiver groove. The receiver groove can't be of a circular shape, it has to have square edges to bite the copper.
I still think that a copper gasket should only be used for frequently torn-down drag race engines tho. I've yet to see one that sealed water and oil passages properly.
Old Jan 23, 2003 | 05:32 PM
turboex's Avatar
Default Re: o-ring reciever groove in the head???? help (rudysfastone)
does anyone run a copper hg on the streets with no problems?
Old Jan 23, 2003 | 07:56 PM
highbrid's Avatar
right now im using copper orings with a stock headgasket. You could probably do the same, then you wont need a receiver groove in the head.
Old Jan 23, 2003 | 08:13 PM
BudaKai's Avatar
Default Re: o-ring reciever groove in the head???? help (highbrid)
What I did.
Old Jan 23, 2003 | 09:02 PM
MotorMatrix.com's Avatar
I am a bad person
Default Re: o-ring reciever groove in the head???? help (tzsir)
why must you use steel o-rings??? the groove in the block should accept the same gauge copper o-ring
Old Jan 24, 2003 | 03:19 AM
turboex's Avatar
Default Re: o-ring reciever groove in the head???? help (MotorMatrix.com)
Well the block was milled 30 thousanths before the sleeves were installed and then It was ran with copper o-rings and leaks, for the owner decided to cut another 20 thousanths of the block to make the grooves only half as deep and run steal rings and a thicker head gasket. He said it works. But everyone i have talked to says stay away from copper for the streets
Old Jan 24, 2003 | 08:07 PM
turboex's Avatar
TTT come one guys, any other answers out there? Does anyone on this board run a copper gasket without problems?
da_33
Jan 11, 2007 11:12 AM
onlinehost
Nov 14, 2005 08:14 PM
mulin
Nov 3, 2004 09:25 PM
boostedel
Apr 6, 2003 09:11 AM
filetofit
Aug 13, 2002 08:49 PM
