nos on gsr
Old May 29, 2005 | 10:47 PM
methodz55's Avatar
Default nos on gsr
i have a zex dry setup on my gsr i was using it and it made a loud pop now my car sounds like **** and it didnt want to stay on i havent taken it apart yet to check it because i have another car in garage.what could have happened ??? i took my spark plugs out one of them was black i think the block is done ?? any suggestions???
Old May 29, 2005 | 11:28 PM
teddy_dc2's Avatar
how many shot? built motor?
Old May 30, 2005 | 10:17 AM
methodz55's Avatar
Default Re: nos on gsr (methodz55)
it was a 55shot h,i,e,manifold it sounds like a wrx
Old May 30, 2005 | 11:00 AM
twkdCD595's Avatar
could be a blown headgasket.
Old May 30, 2005 | 11:13 AM
DvD3's Avatar
B A N N E D
Default Re: nos on gsr (twkdCD595)
did a check engine light come on? if the CEl came on check the code
Old May 30, 2005 | 07:58 PM
methodz55's Avatar
no check engine nothing my motor viberates like crazy and its has a knockin noise
Old May 30, 2005 | 08:09 PM
Ls1 FD3s's Avatar
do a compression test, probably detonated and cracked a ringland. Or just straight melted them because a dry kit is the worst **** you can do to a honda. Stock honda injectors are maxxed out as it is from the factory, now you have bolt ons, and a dry kit. How the hell is the ECU going to add more fuel to compensate for nitrous? It cant, sorry for the rant, but this is why everyone on honda-tech says " 55 shots of naawzz will implode ur engine"
PROPER SETUPS, KNOWLESGE, and TUNING are your freinds.
Old May 30, 2005 | 08:27 PM
methodz55's Avatar
thanks for the input ima take the head and do ls\vtec
Old May 30, 2005 | 08:47 PM
Ls1 FD3s's Avatar
make sure you dont rev the LS/VTEC past 8000 with a stock bottom end. Or else your going to be in the same boat again,,, except with spun rod bearings this time around...
Old May 31, 2005 | 04:27 PM
methodz55's Avatar
Default Re: nos on gsr (Ls1 FD3s)
na i will polish and balance crank and shot peened rods with arp bolts and cp pistons 11:5 comp
Old May 31, 2005 | 04:32 PM
Ls1 FD3s's Avatar
that will help, but its the bore to stroke ratio you have to look out for, the geometry of the engine has to be there.
Old May 31, 2005 | 04:41 PM
tegturbo's Avatar
a dry kit isnt the worst thing you can put on a honda the zex kit is safe i ran one on my ls integra for a summer with a 75 shot and used 4 bottles no probs at all. and i drove the hell out of it at the drags.i love mine kit know i got a turbo and a b17 so this should be more fun.
Modified by 1.7turbo at 12:02 AM 6/1/2005
Old Jun 1, 2005 | 05:30 PM
NinjaTurtles's Avatar
Default Re: nos on gsr (1.7turbo)
bent valve
Old Jun 1, 2005 | 08:54 PM
FRANK_WHITE's Avatar
check oil and coolant overflow, do a compression test and/or check the cat can be clogged (happened to me in my prelude)
integra123
Mar 7, 2006 06:54 PM
ken00si
Oct 11, 2005 04:49 PM
Gdub00lude
Sep 12, 2005 07:03 PM
94integrablur
Apr 26, 2002 05:43 AM
redteg1
Dec 4, 2001 05:54 PM
