NOS on a B20V High Comp
Old Jul 30, 2013 | 06:33 PM
rexB20vtec's Avatar
Default NOS on a B20V High Comp
Don't know if this is the right section but anyways here go my question.
So I been thinking about running a NOS kit on my built.
I have a B20V 12:5:1 compression with a b16 head stage 2 Crower cams springs etc.
just wanting to know what be the best kit, wet or dry. And is there anyone out there that has done a similar built that I'm doing. Any feed back well help.
Old Jul 31, 2013 | 03:49 AM
diatibe24's Avatar
Default Re: NOS on a B20V High Comp
Go wet and ditch your Platinum plugs. Run copper plugs and preferably one degree cooler.
Old Jul 31, 2013 | 05:04 AM
nealnanoHX's Avatar
No go dry kit, larger injectors and fuel pump and have the nos kit controlled and tuned by the ECU. Hondata and Neptune can control the spray and add more needed fuel via the injectors, best and safest way to run spray. Just like turboing a car when you add spray you NEED to have the motor tuned to run safely.
Old Jul 31, 2013 | 06:04 AM
rexB20vtec's Avatar
thanks for the feed back I think im going to run a wet system I been researching and everything is pointing to a wet system
Old Jul 31, 2013 | 05:58 PM
seelback's Avatar
run a dry kit with it controlled by the ecu.
Old Aug 1, 2013 | 03:26 AM
SiRCiviC94's Avatar
Lots to learn. A dry kit is the way to go. Pulse the extra fuel
Through the Injectors with a tune. And use a wot switch
Old Aug 3, 2013 | 08:05 AM
SHRUGS*'s Avatar
Everyone saying dry controlled by ecu knows what's up. Wet kits work just fine but when the relay or solenoid stops working on the fuel side.....boom!
I've been running a 125 shot direct port for a couple years now with no problems. Made 319whp on a b18c 12.1 c/r
Old Aug 4, 2013 | 05:21 AM
rexB20vtec's Avatar
thanks again everyone I really do appreciate all the feed back
Old Aug 4, 2013 | 09:38 PM
Jimmynitro's Avatar
Run non projected ngk 8 spark plugs. N dry shot Hondatas300. w 750cc injectors n make sure u have enuff fuel pump
I had a 13-1 comp b20v on 100 shot years ago was fun
Old Aug 4, 2013 | 09:41 PM
Jimmynitro's Avatar
99% big power Honda nitrous guys are running a dry shot controlled by kpro or a s300 ,, idk where ur finding wet is better. Check. Jakespec or richiewerks on the net. There both deep in the nitrous game. As well as. MY self. I started w wet kits but switched to ecu controlled dry shots now
Old Aug 4, 2013 | 10:23 PM
wantboost's Avatar
Who is Mr Robot?
Do you simply have the ems add fuel when the nitrous is engaged?
Old Aug 5, 2013 | 01:05 PM
got-vtec?'s Avatar
how do stock sleeves hold up with a high compression and a big shot? thinking of doing a nitrous build after im done with my current project.
Old Aug 5, 2013 | 01:35 PM
nealnanoHX's Avatar
Yes that is correct. Much safer way to do it and you will make more power.
Old Aug 5, 2013 | 01:36 PM
nealnanoHX's Avatar
Its all in the tune and pump gas will most likely not do the job.
Old Aug 5, 2013 | 01:40 PM
got-vtec?'s Avatar
pump e85 perhaps?
Old Aug 5, 2013 | 01:53 PM
nealnanoHX's Avatar
Yeah E85 will get you there.
SPOONfdEK
Jul 15, 2003 03:56 PM
nickdoe
Jun 3, 2003 08:05 AM
Rory Breaker
Jan 21, 2003 08:23 PM
Toretto
Jan 9, 2002 09:33 PM
DaNish
Nov 22, 2001 07:21 PM
