Is this normal!?!??!?!
Old Apr 17, 2005 | 04:55 PM
0ptimus prime's Avatar
Default Is this normal!?!??!?!
My set up involves a 50 trim T3 turbo on a D15B vtec engine. Can't find any bad intercooler piping leaks.....now for the nonsense.
My turbo reaches full boost by 3k RPMS....reaches a steady 8 lbs. However, by the time it reaches 6 - 7k rpms...it drops down to ~ 4.5 - 5 lbs of boost. I can't find any leaks, however, i do have a lousy downpipe. It goes from 2.5 - ~ 1.75 (long story).
What could be the cause of me loosing so much boost by redline? it pulls nice for a little bit, then drops in boost rather dramatically. Any tips? Thanx.
- optimus
Old Apr 17, 2005 | 04:56 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Is this normal!?!??!?! (0ptimus Prime)
the downpipe
Old Apr 17, 2005 | 05:09 PM
Default Re: Is this normal!?!??!?! (wantboost)
I'm not trying to doubt you or anything, but out of honest curiosity, why would it be the downpipe? Is the restriction causing the turbo to slow down or something?
Old Apr 17, 2005 | 05:56 PM
bump!
Old Apr 17, 2005 | 07:08 PM
wantboost's Avatar
Who is Mr Robot?
yea, as the car revs higher, more exhaust gases are being forced out... turbos work the principle of pressure differential... more pressure before the turbo, less after. in the higher rev ranges, the backpressure from the small exhaust is nearing that of the exhaust manifold, causing boost to drop off.
upgrade the dp and youll find quicker spool and full boost till the rev limit
Old Apr 17, 2005 | 07:38 PM
you are the man
Old Apr 17, 2005 | 07:40 PM
wantboost's Avatar
Who is Mr Robot?
i know, lol.
now only if someone on this board knew anything about holset turbos
Old Apr 17, 2005 | 07:57 PM
Evanmb44's Avatar
thats what i had happening on my old setup when i was running a stock cat. once i switched to a 2.5 test pipe it held boost fine until redline...problem solved. then i threw a whole new setup on the car
Powelly
May 4, 2009 02:32 AM
dont_tri
Jul 1, 2008 04:40 AM
Specail Ed
Dec 20, 2007 12:59 PM
rickturboteg
Aug 27, 2006 09:23 AM
Mr_Bojangles
Feb 11, 2005 02:08 PM
