noob ? here... AFC, how does it work?
Old Apr 26, 2003 | 04:33 PM
joey1320's Avatar
Default noob ? here... AFC, how does it work?
Okay I have read the different posts on the setup of the AFC, and how to tune it. Fine, now I need to know how does it exactly work? The pupose and reason behind it...
The main reason is to try and explain my father, he's old school and has no idea what i'm talking about... plus I want to know before i get into it...
PS. Don't flame, i tried searching but the responses were of no use...
Old Apr 26, 2003 | 04:50 PM
skhonda's Avatar
Default Re: noob ? here... AFC, how does it work? (joey1320)
Well... in general, it controls how much fuel to give at certain rpms... you can also change other things like v-tec engagement point, throttle settings, etc.
I don't know a whole lot about it, but those are some of the things i had to change when i turbocharged my d16y8 because i was giving much more air to my engine, and now it needed more fuel.
Old Apr 26, 2003 | 04:56 PM
NoBoost's Avatar
its a piggy back system. wut it does in essence is trick ure cars stock ecu into thinking everything is normal when in fact u are changing fuel settings throttle settings and vtec engagement points. all it is; is basically an ecu "hack".
Old Apr 26, 2003 | 05:05 PM
joey1320's Avatar
Default Re: noob ? here... AFC, how does it work? (NoBoost)
thanks for the response, i went to thedropshop.com and found some useful info. on it too. you learn a lot here
Old Apr 26, 2003 | 05:34 PM
inspyral's Avatar
The AFC modifies the MAP signal to get the ECM to alter the injector pulse.
Old Apr 26, 2003 | 08:19 PM
Ek00fbp's Avatar
Default Re: noob ? here... AFC, how does it work? (inspyral)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral &raquo;</TD></TR><TR><TD CLASS="quote">The AFC modifies the MAP signal to get the ECM to alter the injector pulse.</TD></TR></TABLE>
Thanks for breaking it down for us noobs
BlueShadow
Oct 7, 2004 06:02 PM
chronodyne28
Jun 19, 2004 12:13 PM
2khb
Dec 10, 2003 02:24 PM
Westrock2000
Mar 22, 2003 03:56 AM
ITR41
Oct 28, 2001 11:02 PM
