Non Daily Drivers
Old Jan 6, 2006 | 08:41 AM
fanta!'s Avatar
Default Non Daily Drivers
if your turbo car is not a daily driver...
what precaustions (sp??) do you take before driving it again? im talking about not driving it for a 1-2 weeks and then driving it again.
check fluids, let car fully warm up?
Old Jan 6, 2006 | 11:12 AM
tgreaves's Avatar
Default Re: Non Daily Drivers (fanta!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fanta! &raquo;</TD></TR><TR><TD CLASS="quote">
check fluids, let car fully warm up? </TD></TR></TABLE>
I let mine warm up and check the fluids before I start it.. Thats about it.. Also check the air pressure in your tires before you go out..
And I always stretch my arms before driving my civic, manual steering and welded diff, need I say more..
Old Jan 6, 2006 | 11:21 AM
PM-Performance's Avatar
I just always check the fluids and let it warm up before driving. I just take it easy then for the first few minutes to make sure everything is cool then boost like a ****
Old Jan 6, 2006 | 12:06 PM
platinum00's Avatar
as long as its not sitting for months at a time you should be fine.
start her up and make sure you temps are ok and you good.
platinum.
Old Jan 6, 2006 | 03:13 PM
fanta!'s Avatar
Default Re: Non Daily Drivers (platinum00)
Old Jan 6, 2006 | 06:38 PM
Tony the Tiger's Avatar
Pull the oil pan and drop the crank to check the bearings, and then yank the pistons out to check the condition of the rings. Then put some new sleeves in and then you are good to go j/k
I usually won't start boosting if the car was sitting for 1+ month because of the fuel in the gas tank degrading over time. You should fill it up with fresh gas before unleashing the beast
Old Jan 7, 2006 | 06:27 AM
JDM00SI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 &raquo;</TD></TR><TR><TD CLASS="quote">as long as its not sitting for months at a time you should be fine.
platinum.</TD></TR></TABLE>
Ricky616
Meets & Events
Aug 17, 2013 11:33 PM
thawley
Dec 30, 2006 06:31 AM
arsenaldragster
Jul 31, 2003 09:40 PM
94HybridEX
Feb 20, 2003 11:57 PM
