No Spark...WHY??????
Old Jan 11, 2005 | 01:09 PM
98gsrTEG's Avatar
Default No Spark...WHY??????
i have a turbo 98 integra gsr and at the moment does not run because it is not getting any spark. I have known my ignitor was going bad for some time so i replaced that, and still nothing. so i replaced my ignition coil, spark plug wires, swaped ecu's swapped emanage's, new plugs, new main relay fuse, the cap and rotor are about 1000miles old. what the hell could be causing me not to get spark after i replaced everything that i can think of that would cause this?? the only thing i can possibly think of is the ignition harness on my emanage. but the emanage has been in for more than a year without a problem. how could it have gone bad? i didnt even know that an ignition harness could go bad
any help would be greatly appreciated
Old Jan 11, 2005 | 01:12 PM
RacerXI's Avatar
Default Re: No Spark...WHY?????? (98gsrTEG)
Does anything come on w/ the turn of the key? If not check your main relay under the hood.
Old Jan 11, 2005 | 01:14 PM
98gsrTEG's Avatar
Default Re: No Spark...WHY?????? (RacerXI)
yeah it turns over, and i know i am getting fuel, but i also have a spark tester and it is showing no spark on all 4. if the main relay was bad it wouldn't even trun over
Old Jan 11, 2005 | 03:09 PM
SPOON_BeIgHtEeNsEe's Avatar
i just had the same problem with my z6... swapped in a new (used) dizzy and started right away... was the ignitor new or used??? could be bad also if used... it also could be ur cap or rotor too... u should replace those also...
Old Jan 11, 2005 | 04:08 PM
98gsrTEG's Avatar
Default Re: No Spark...WHY?????? (SPOON_BeIgHtEeNsEe)
all the components that could go bad in the dizzy have been changed already and its still not working
Old Jan 11, 2005 | 04:09 PM
93turbo16's Avatar
try just a new dizzy and see what happens. Never know with electronics.
Old Jan 11, 2005 | 06:52 PM
98gsrTEG's Avatar
Default Re: (93turbo16)
any way the harness itself could have gotten botched in some way to make it not spark?
Old Jan 12, 2005 | 08:57 AM
98gsrTEG's Avatar
anyone????
Old Jan 25, 2005 | 06:06 PM
EK9 B16B TSL's Avatar
You might wanna try continuity tests between the wires coming from the ecu, going to the distributor.
Old Feb 7, 2005 | 08:45 PM
usfsfirefighter0's Avatar
Is the wireharness arcing on the motor at all there maybe short? If not the distributor it could also be the computer try put a your ecu in a friends car with similiar swap, u can try to putt another ecu in yur car, or u can also do this with distributor. Also check check ign fuse (15 amp) in the fuse box in the dash and the engine bay ? Hopefully this works or steers u to the problem but if u find the problem please let me know ok?
Old Feb 7, 2005 | 08:52 PM
D-tuned's Avatar
Default Re: No Spark...WHY?????? (usfsfirefighter0)
check the coil fuse under the dash.
Old Feb 9, 2005 | 11:30 AM
Default Re: No Spark...WHY?????? (2000civicsi)
thats what i just said<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000civicsi &raquo;</TD></TR><TR><TD CLASS="quote">check the coil fuse under the dash.</TD></TR></TABLE>
stevejames
Nov 24, 2016 01:23 PM
eagle459
Sep 7, 2008 09:01 PM
mugeneghatchie
May 15, 2008 12:48 PM
widecrx
Jul 1, 2007 05:14 PM
racerboyb18c1
Nov 18, 2003 07:46 PM
