no spark need help..searched and checked everything
Old Aug 31, 2007 | 08:28 PM
turbosol18's Avatar
Default no spark need help..searched and checked everything
so today i put in my dsm 450cc injectors with the resistors and i started it up to make sure there wasnt any leaks and the car started fine and idled good for about 2min..after that it just died out and shut off
i then tried to turn it bak up and it just cranks and no start? I checked and there is no spark
is a mini-me swap with t4 turbo, dsm 450cc injectors and im still using the original distributer from the 1.5 non-vtec head. Could it be that the distributer finally gave out? or the ecu? i checked all fuses, i checked the main relay and it clicks ect. Any ideas please help a brother out
btw im still waiting on my ecu to come back from being chipped and base mapped. Right now i have a stock p06 ecu and i had a check engine light code 16 which was fuel injectors
Old Aug 31, 2007 | 08:37 PM
racin jasin R's Avatar
Default Re: no spark need help..searched and checked everything (turbosol18)
see if you cant borrow a dizzy...
Old Aug 31, 2007 | 08:42 PM
turbosol18's Avatar
Default Re: no spark need help..searched and checked everything (racin jasin R)
you think my dizzy is the problem?
like i said it just gave out from one sec to the other
Old Aug 31, 2007 | 09:21 PM
62ndsoldier's Avatar
if u check for spark properly and you are not getting any spark anywhere check the cap make shure its fine, if the cap is good on the inside then just go get ya a whole new dizzy, if ur tight on cash i go and grab em at the junkyard cheap
B16Civic93
Jan 20, 2014 04:30 PM
19integra91
Mar 15, 2008 09:38 AM
turbosol18
Aug 31, 2007 08:14 PM
BALLIN H22 EK
Feb 24, 2006 12:36 PM
Teglove2
Sep 13, 2004 05:58 AM
