no oil
Old Oct 9, 2003 | 07:14 PM
goofball123321's Avatar
Default no oil
I just put on my turbo kit and i started it w/out spark plugs for 1 min in 30 sec intervals, w/ the oil return off. still no oil is coming out my battery is dead and its charging. how long does it usually take to get oil in there?
Old Oct 9, 2003 | 07:21 PM
DaveF's Avatar
Default Re: no oil (goofball123321)
pull the spark plug wires off and crank it till oil comes out..than u will be safe..it should only take a few seconds. its like the first spot the oil goes after leaving the pump(if you tapped for oil at the oil pressure sensor.
Old Oct 9, 2003 | 07:23 PM
twkdCD595's Avatar
Default Re: no oil (2.2Lcivic)
I would say you either need to check your oil or your pump is not make enough pressure anymore.
after a minute of cranking you should have seen oil.
EGgoJDM
Dec 1, 2009 12:05 PM
da9runner!
May 12, 2008 06:20 PM
dominate9
Dec 15, 2004 05:51 PM
