No fuel? car wont start after turbo install...... please help
ok so i finished up my turbo build this weekend, well so i thought. went to start it and there wasnt any fuel. My car is a 96 honda civic ex. with a d16y8 single cam. Now obviously its a fuel proublem so ill tell you my set up. i have DSM 450's (blue tops), i have the proper injector clips (not 100% if the wiring is right) i was wondering if i have the wires mixed up if itll keep the injectors from opening? if not then i think my other proublem is wehre i put resitor box, i found my dead end plug under my manifold check it for voltage found the 4 wires i needed and spliced the box in (i hope my connections are 100%). but after all of this and about 5 hours of screwing around with the damn thing, there isnt anyfuel gettin into the cylinders. So i was just wondering if anyone knows whats goin on, or if anyone had a problem similar to this? any help is appreacheated. Thanks.
Mr. Badwrench
Re: No fuel? car wont start after turbo install...... please help (Bobbyt5408)
first see if you have 12v at each injector. and if not go back and look at your resistor box wiring.
ragethemachine86
08-05-2006 12:29 PM
