nitrous users- signs and symptoms
are there any signs or symptoms when your bottle is running low? also when i purge the n2o isnt visible. and is there a certain way to fill the bottle?, i think i got ripped off last fill, because it ran out so fast and felt like i was squeezin oxygen...
bottle pressure is everything . find out what the bottle pressure is and if it feels like its a weak spray or kinda like pulsating, then your prob close to tapepd out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2k1 GSR »</TD></TR><TR><TD CLASS="quote">are there any signs or symptoms when your bottle is running low? also when i purge the n2o isnt visible. and is there a certain way to fill the bottle?, i think i got ripped off last fill, because it ran out so fast and felt like i was squeezin oxygen...</TD></TR></TABLE>
If you were sqeezin straight oxygen you wouldn't have a motor.
Bottole pressure needs to be at least 900 to get a good flow of n20. Cold bottle equal bad results. If you don't see anything out of the purge, that means it's air.
.Bottole pressure needs to be at least 900 to get a good flow of n20. Cold bottle equal bad results. If you don't see anything out of the purge, that means it's air.
is there a way to find out if u get a bottle filled incorrectly? like they half way fill it up? how much does an empty and full bottle weigh?
a 10 lb nos bottle weighs i think about 15 lbs and then with 10 lbs of nos you got a 25 lb bottle so just weigh it and if its full it should weigh actually a little under 25 lbs cause empty its like 14 lbs 8 oz.
