nitrous question
Old Dec 2, 2001 | 08:14 PM
redteg1's Avatar
Default nitrous question
around how much can i expect to cut off my e.t. with a dry 55shot on a gsr??
Old Dec 2, 2001 | 08:21 PM
ForcedAccord's Avatar
Texas B*tch!
Default Re: nitrous question (redteg1)
A few tenths I would imagine, what do you run stock?
Old Dec 2, 2001 | 08:43 PM
captain4g63's Avatar
I know someone with a 90 4dr lx civic w/ b16a, with slicks runs 14.0, with 80 shot he runs 12.6.
So to answer you, expect 3/4 seconds if you get traction. You will see a big trap speed difference; 7-10 mph
Old Dec 2, 2001 | 08:51 PM
redteg1's Avatar
Default Re: nitrous question (ForcedAccord)
i run a 15.4@92mph ...yea pretty stockish
Old Dec 3, 2001 | 04:33 AM
dyezak's Avatar
First off the 92mph you listed is good for about a 14.7sec run in a FWD, or if you're really good (ie AWD) a 14.0-3. So you either need to practice launching or shifting.
A rule of thumb for hp is every 10hp will net you about 1mph in the 1/4. So you should run around a 97mph 1/4...which with perfect traction and good solid shifting is worth a 13.7. I ran 4 13.51's in a row at 99mph before...so there's a yardstick for you. I think that 50-60hp shot should put you in the 13's if you know how to drive.
Old Dec 3, 2001 | 10:05 AM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: nitrous question (dyezak)
For Dry kits, don't expect to gain as much as you think you're going to gain. Depending upon the kit - I'm assuming you're going with zex 55 65 75 horsepower shots. I think it's 55 shot - .7 off, 65 shot 1.0 off, 75 shot 1.2 seconds off. I ran 75 shot zex on my hatch and dropped 1.2 seconds.
Old Dec 3, 2001 | 10:44 AM
redteg1's Avatar
Default Re: nitrous question (RealTypeR)
thats it?? hmm..i would've expected more. so is the difference between a 75shot wet and 75shot dry the same or wat?
Old Dec 3, 2001 | 12:08 PM
dyezak's Avatar
OK RealTypeR...what's heavier, a pound of feathers or a pound of bricks.
If the kit is putting out the advertised 50hp level, it doesn't matter if it's wet or not when it comes to performance...50hp is 50hp. Use your heads.
Now...if the kit ISNT putting out it's advertised HP rating than some care needs to go into seeing why it isn't. Are you running overly rich? Is your ignition up to the task? Is your clutch slipping? Do you have bad compression? Or is it putting out it's advertised power and you simply can't drive it to the fullest of its potential on the first run...remember...you must relearn how you drive a car once you squeeze it.
Oh and one more thing...on a low traction application such as street oriented FWD's it's best to look at MPH not ET for power gain/loss. ET only show's how well you are using that power (ie traction and shifting).
So RealTypeR...what was your MPH before and after?
[Modified by dyezak, 9:11 PM 12/3/2001]
Old Dec 3, 2001 | 12:33 PM
paulzy's Avatar
you guys forgot about bottle pressure...low bottle pressure will really hinder performance
Old Dec 3, 2001 | 12:37 PM
dyezak's Avatar
Default Re: nitrous question (Slow_ass_4dr)
BAHH...I was just throwin a few out there. My whole point was that 50hp is 50hp no matter what way you slice it Mr President.
"Mr President, did you add 50hp to your car?" Reporter
"What exactly IS the definition of 50hp?" President
Old Dec 3, 2001 | 03:05 PM
BoM's Avatar
BoM
yeah but remember fool, how its distributed
its suppose to be even!
Old Dec 3, 2001 | 05:14 PM
Default Re: nitrous question (BoM)
I was going to give you a hard time, but you obviously posted in the wrong forum
_______
Old Dec 3, 2001 | 07:46 PM
Sleeper in Seattle's Avatar
Default Re: nitrous question (captain4g63)
Back when I was all motor, I used a 50 shot dry NOS kit and ran 15.4 with out Nos(Intake, headers,and exhuast) and with the 50 shot I ran 14.4 at 99mph.
Old Dec 4, 2001 | 09:12 AM
Default Re: nitrous question (Sleeper in Seattle)
50 Horsepower dry shot DOES NOT = 50 horsepower wet shot. I don't know where you are getting your information from, but you are incorrect. We tested it several times. I gained 54 whp and 65 ft/lb torque with a 50 shot WET kit, and with a 65 shot DRY kit, my friend gained 45 whp. They are two completely different kits and Wet and Dry kits work entirely different. Yes, your mph does increase. I'm just stating the facts on what I know and what I gained. I gained 1.2 sec on a 75 shot in my dx hatchback. I never ran my Type R off the bottle, but my trap is 104.79 just in case you care.
Old Dec 4, 2001 | 09:58 AM
PM-Performance's Avatar
are you on drugs boy????
you must not know that much about n20
a 50 shot wet or direct port will give you more power than a 50 shot dry, its all about even distribution
there was a guy on the r forum had the exact same set up and did the same exact hp as me , but he had 50 shot direct port and i had 85 shot dry, granted mine had issues with leaning out right away and we shut it off , but wet and especially direct port are a hell of alot more efficient.
you sound like one of those people who say 300watts is 300 watta, why not get a pyramid amp rather than xtant?
its all about efficientcy bro , you got a lot to learn.
Old Dec 4, 2001 | 10:19 AM
xXsarcasmXx's Avatar
Default Re: nitrous question (itr206)
yup efficiency is the key......but I got another q about n2o......
would the compression ratio need to be changed if I was to run a 75 shot (wet) on an H22a or H23???
Old Dec 4, 2001 | 11:35 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: nitrous question (xXsarcasmXx)
NOS luvs compression, just gotta tune it right. Less room for error.
When in doubt, up 2 jet sizes on the fuel and work back down.
Better foul a set of plugs that toast a couple of pistons.
Old Dec 4, 2001 | 12:26 PM
Default Re: nitrous question (Mista Bone)
yea bro everyone tells me im nuts for juicen the hell out of my r because of the compression. . . . f that , if you know what your doin and get it tuned right you will be fine and im gonna prove that when i go 100 shot on mine .
Old Dec 4, 2001 | 04:21 PM
I know my fair share about N2O and I agree that it's about efficiency. Wet is more efficient that dry. I've run both dry and wet on my vehicles. Fuel is everything. We already have a Type R running 100 direct WET and it's hella fast. He's hoping to dyno 260-280 whp. I admit I have a lot to learn, but I feel I know more than you think I do. That's if your opinions were directed at me.
Old Dec 4, 2001 | 06:51 PM
xxplosif1's Avatar
a dry kit will give you flywheel hp and a wet kit will give you wheel hp....is that right RealTypeR? You said you gained 54 whp with a 50 shot wet, and your friend gained 45 whp with a 65 shot dry. If your right well thats pretty impressive, and this is the kinda of numbers i am looking for with a wet kit.
Old Dec 5, 2001 | 02:21 AM
Mista Bone's Avatar
D Tranny Guru
what is heavier, ounce of feathers or ounce of gold???
and who the hell is Troy?
Old Dec 5, 2001 | 07:07 AM
na not you , i was agreeing with you .
it was going to that dyezak
your right on the nose bro.
JDM91EF2
Mar 16, 2017 11:33 AM
GSRontheBottle
Nov 25, 2002 09:59 PM
fast93accord
Oct 9, 2002 07:29 PM
Rah Rah
May 13, 2002 10:17 AM
sirlock
Jul 17, 2001 09:59 AM
