nitrous question
Old Feb 8, 2004 | 02:14 PM
MysticSpade's Avatar
Default nitrous question
ok i just got my bottle back from being filled. i have a split purge line to fire out both sides of the crx. and i noticed a small leak (not so small really) goin from the steel hose to the solenoid. i tried to tighten it but it won't tighten no more.
question #1: how much nitrous do they usuall put in a 10-15 lb bottle
question #2: if a purge line is split does it use 2x the normal amount.
cuz i purged maybe 10 times holdin it for approx. 1 sec at max diff times and now all i got is air.
Old Feb 8, 2004 | 03:55 PM
turbo96wr's Avatar
Default Re: nitrous question (MysticSpade)
check the fittings to see if there is anything on the threads or the sealing angle on the fitting make sure it does not have a slight imperfection on it.
Boosteddc2gsr
Jul 4, 2003 02:13 AM
Sohc Driver
Dec 13, 2002 08:51 PM
