NITROUS question
Old Feb 25, 2005 | 03:54 PM
95accordh22a's Avatar
Default NITROUS question
if i buy a nitrous kit that is wired to run on wide open throttle can i make it run when i want instead of wide open throttle?
Old Feb 25, 2005 | 05:56 PM
mrbsponge's Avatar
depends on the throttle activation method, like zex uses a rpm switch and nos uses a regular microswitch
Old Feb 26, 2005 | 08:31 AM
Default Re: (mrbsponge)
alright so if it is a regular microswitch i can or no?
Old Feb 26, 2005 | 08:35 AM
mrbsponge's Avatar
if it is anything other than than zex yes, if it has a regular switch that you can see, and physically touch then yes, you can activate it whever you want but i recommend to not use it below 2500 rpms and never use it on partial throttle
Rad Racing
Sep 24, 2005 07:00 AM
Si Erik
12
Oct 4, 2003 07:53 PM
cr-x si
Oct 2, 2002 08:33 AM
stangkilla
Nov 1, 2001 07:50 PM
