Nitrous gone bad
Anything from forgetting to install the nitrous jet, to running a 75+ dry shot on a b16 with sohc injectors
Also my good guess is if the fuel mods weren't done for this motor neither were the ignition which would include 4 degrees of retard. If this was not done it would explain the high amount of heat and cylinder pressures along with a lean condition. BOOM. Use of nitrous isn't any more dangerous than a turbo. Both REQUIRE tuning.
[Modified by BlackCivicD16, 10:03 PM 3/2/2003]
bro its like this but theres a few things you must remember before you **** with anykind of nitrous,turbo etc. You have to figure out will your car be able to handle the **** dont listen to all the people who sell you the sht like yeah it can take a 75 shot they just tellin you that to buy it and make them money yo. on the real a stock mototr to be realistic and safe shouldnt do more than a 55 shot to be even safer a 40 shot. but you must have a high performance engine for a high performance part most of yall know what im talkin about around chrismas i blew my ****** motor it cost me 900 to fix and replace the head cause i fucked up cylinder valve section 1,3 and 4 the **** was no joke and i used a zex 65 shot on my accord . It had the zex spark plugs i changed the oil,fuel filter retarded the timing all that **** thinkin i was safe but i didnt change the timing belt. when i first tried it my car wit the 65 shot i was like oh shiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiit it moved but there was that split second that i went lean and it was a rap for me all them valves was done i know cause i smelled some melted **** in the engine under the hood once i looked and saw it i was like what the **** and they told me i literally warped the head so it was no good had to buy another one 700 bucks but i got new valves. Now i said to myself man with that ****** omoney i should have just held off of the nitrous and opted for my swap im not tryin nitrous for a good minute after i get my swap.
hey laughin, its Mike, one of brians friends from UW-EC, u guys should make a trip back here before school gets out so we can all goto rock falls!
Yeah, lemme hop in my Concorde, hit up the Rolls Royce VTECKH Mach 2 powAr and I'll be there in 4.
yeah N2O can be a problem without the proper amounts of fuel. that's one reason why i like the wet/DP systems along with a 255 pump. i ran 100+ shot DP on my B18C, 12 bottles last year. i just took the head off of it yesterday and it looks good. no sleeve, piston or ring damage that i can see so far.
if you run out of fuel then predetonation can be severe enough to crack the sleeves, ruin rings or melt pistons etc. i've seen it before.
damn that sucks man. I ran a 60shot on my si for about a year back in the days. I wasnt very pleased so i got rid of it and got turbo. So far, turbo has become money after money
btw, i ran 14.5@98mph w/ 2.6 '60ft
with my 60shot i/h/e
How were you hooking up on a 100+ shot?
That's what I figured. I want to go to a 100 shot, but I'm sure I'll just burn up my khumos.
Looks more like a lack of a block guard than detonation. best way to tell is to pull teh pistons and see if the ringlands are cracked.. If they are cracked.. detonation. If not, you should have run a block guard.
thats why they were invented.
at least thats my opinion on the matter.
jason
jason
jason
jason
J/K
it's always good to hear from you Jason.
if those sleeves cracked from just being weak while running a 75 shot (without detonation) then i'll be surprised. i say this because i used a 100 shot DP system with 11:1 C/R last year, with stock sleeves and no blockgaurd, and the block looks fine. i just took it apart last w/e for the first time since last May. 12 bottles all together with a few occasions of lean conditions, but yet the sleeves are in perfect shape. so i'm thinking that there was severe detonation from a lean condition or incorrect ignition timing, even though it wasn't a crazy high injection.
sharkey65a
Jul 4, 2003 01:32 PM
