Nitrous backfire through intake - possible damage?
Old May 22, 2004 | 10:13 PM
landon's Avatar
Default Nitrous backfire through intake - possible damage?
I have my wet nitrous wired to a switch, one with arm and one with spray. Finished up last night, sprayed a few times with it (50 shot) and decided to head to the track. Anyway, to make a long story short, i was losing traction, and like a moron, i let up on the throttle, leaving the switch on. When I got back in it, a huge BOOM and flames out of the intake, as well as the exhaust I was told by onlookers. The car ran for a second, then sputtered out and died. I tried to start it again, and after a few min of trying, i finally did. Seems to run fine now, so could i be lucky and have gotten away once?
Old May 22, 2004 | 10:20 PM
B18C1CYA's Avatar
Default Re: Nitrous backfire through intake - possible damage? (landon)
i had a nitrous backfire in my car on time it took out the tb,map sensor, and iac valve, but i was runnin a 100 shot wet, thats one of resons i dont use nitrous any more turbo owns
Old May 22, 2004 | 10:40 PM
landon's Avatar
so, if its all running the way it did before, i oughta be cool? i have no CELs or anything
Old May 22, 2004 | 10:52 PM
Pengo's Avatar
Default Re: (landon)
least ur intake mani didn't blow up like one of those new civic ones would've
you should change that spray switch to a button for safety reasons i'm sure you can figure out.
hope your engines fine. good luck
Old May 22, 2004 | 11:09 PM
1316130057's Avatar
Default Re: (Pengo)
I've seen nitrous backfires break and bend throttle bodies, blast valves into cylinders, blow heads off of cars, set engines on fire, blow head gaskets, melt all sorts of ****, and blow a myriad of pipes off of manifolds. If I were you, I'd inspect literally everything in the intake and exhaust stream.
Old May 22, 2004 | 11:25 PM
SeanEF's Avatar
If your map sensor was f-d up you would know it...
Old May 22, 2004 | 11:50 PM
FlexW99's Avatar
Default Re: (SeanEF)
yeah, the countdown is on though.be paranoid for awhile.
Old May 23, 2004 | 02:14 AM
Kwuaymaikrup's Avatar
Default Re: (FlexW99)
You will blow the welds off your intake...and then me and the mad scientist will have to tear it down to replace the piston rings you fried.
Old May 23, 2004 | 06:20 AM
honda_joe's Avatar
Default Re: (Kwuaymaikrup)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kwuaymaikrup &raquo;</TD></TR><TR><TD CLASS="quote">You will blow the welds off your intake...and then me and the mad scientist will have to tear it down to replace the piston rings you fried.
[ricer crowd] ooooooooooooooooooooooooooooooohhhhhhhhhhhhhhhhhhh hhh[/ricer crowd]
Old May 23, 2004 | 06:29 AM
G
sh!t happens.
lol.....i had nitrious back fire on my teg when i was racing a mustang on the highway.. it was loud as hell and my car just cut off.. its was weriod then it cut right back on..
Old May 23, 2004 | 01:38 PM
AzCivic1.6's Avatar
theres a reason you should run nitrous on a WOT switch.
direct port
Old May 23, 2004 | 04:27 PM
m R g S r's Avatar
Default Re: Nitrous backfire through intake - possible damage? (AzCivic1.6)
I'm ran it with a WOT switch and never backfired once. You might want to look into running one of those.
Old May 23, 2004 | 04:40 PM
1316130057's Avatar
Default Re: Nitrous backfire through intake - possible damage? (m R g S r)
WOT switch + 2 step launch control = some serious backfire. Obviously this won't affect everyone with nitrous and a WOT switch, but it will affect anyone with nitrous with a WOT switch and a 2 step.
Doug684
Jan 4, 2004 02:51 PM
david90
Dec 2, 2003 11:06 PM
MooreBoost
Apr 28, 2003 02:58 PM
