Nitrous ?
Old Apr 24, 2003 | 03:01 PM
MooreBoost's Avatar
Default Nitrous ?
What would be easier on the motor, direct port, or standard intake jetting? Also, Im debating on running 75 for track use only, once a month, or a 50 shot and spraying at the strip and occasionally on the street.
I ask because of the theory that intake jetting is hard on the #1 cylinder, but Im also looking for the best reliability.
Thanks,
gmoore
Old Apr 24, 2003 | 03:10 PM
untitled's Avatar
Default Re: Nitrous ? (tegunderpressure)
is your car supercharged?
Old Apr 24, 2003 | 03:22 PM
MooreBoost's Avatar
Default Re: Nitrous ? (88crx91integra)
It is currently, but I may take it off if its messed up again, and spray. Ohh, and I was going Zex if I just go intake jetted. Any more opinions?
gmoore
Old Apr 24, 2003 | 04:09 PM
MooreBoost's Avatar
Ok, broken down-
Would you go Zex Wet? or Zex Dry?
gmoore
Old Apr 25, 2003 | 07:33 AM
untitled's Avatar
you cant do intake shot with the jrsc. you have to spray after the air is boosted. lok around for a plates system. you should probably do wet if you are boosted.
Old Apr 25, 2003 | 08:22 AM
PM-Performance's Avatar
direct port is best
Old Apr 25, 2003 | 09:40 AM
neo1z's Avatar
Default Re: Nitrous ? (itr206)
If you were going to run a dry intake-injected type deal -- you can ensure a better mix in all the cylinders if you tap the intake like 16" away so it has a chance to disperse.
But if youre going to run 75, then I would surely go direct port, or if you have a GSR, go ahead and get the plate kit.
Old Apr 25, 2003 | 02:58 PM
MooreBoost's Avatar
Default Re: Nitrous ? (neo1z)
I have a GSR, if I spray it will be because I took the blower off. Is direct port safer and more reliable than intake jetting?
gmoore
Old Apr 25, 2003 | 04:55 PM
untitled's Avatar
okay yes it is. direct port is the way to go. here https://honda-tech.com/zerothread?id=473488
Old Apr 25, 2003 | 06:05 PM
shockerstickers's Avatar
never have seen probs with zex. its cheap. im poor.
Old Apr 25, 2003 | 09:55 PM
neo1z's Avatar
Default Re: Nitrous ? (shockerstickers)
If youre only planning on shooting 50 - I would choose Zex. Anything above that -I just wouldnt be comfortable putting all that in my intake. I really would choose the alternative on this on 75+.
Old Apr 26, 2003 | 06:58 AM
MooreBoost's Avatar
As of now Im only planning on 50, but you know how that goes, Ill want more in no time. But believe me, if I add more, Ill tune more, I cant afford to mess anything up. Why are you weary of spraying 75 into the intake? Ohh, and what do you prefer? Wet or Dry?
gmoore
Old Apr 26, 2003 | 07:10 AM
untitled's Avatar
i know a few people with zex kits. they werent happy with them. yea they are real safe and all but, you want power man. you can pickup a n.o.s. direct port for like $600 new. when you spray alot into the intake the its not distributed as well as if it were direct port. plus ive ridden in a car where we had it setup a pure dry 50 shot and then switched it to 50 wet. it made alot of difference. good diference. go direct.
Old Apr 26, 2003 | 12:21 PM
MooreBoost's Avatar
Is direct reliable? Reliability/safety is just as important to me as the speed.
gmoore
Old Apr 28, 2003 | 12:47 PM
untitled's Avatar
zex is the safest. but if you are going to run 75 or higher, i would go direct b/c of the added fuel.
Old Apr 28, 2003 | 01:20 PM
allmotorls95's Avatar
i believe nx has a direct port system but i could be wrong as well
Old Apr 28, 2003 | 01:36 PM
dohc-nyne's Avatar
< doesnt use cheater gas
Old Apr 28, 2003 | 02:11 PM
MooreBoost's Avatar
Default Re: (dohc-nyne)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohc-nyne &raquo;</TD></TR><TR><TD CLASS="quote">&lt; doesnt use cheater gas
Good to know, now tell me somethin usefull you post *****.
gmoore
Old Apr 28, 2003 | 02:15 PM
Malice's Avatar
New User
LOL!!! that was the most informative post EVAR!!!
Old Apr 28, 2003 | 02:21 PM
dohc-nyne's Avatar
calm down u guys take it to the heart too much.....
Old Apr 28, 2003 | 02:30 PM
MooreBoost's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohc-nyne &raquo;</TD></TR><TR><TD CLASS="quote">calm down u guys take it to the heart too much.....</TD></TR></TABLE>
Well write a book about it then help answer my question.
gmoore
Old Apr 28, 2003 | 02:49 PM
sharkey65a's Avatar
Default Re: (tegunderpressure)
yes its true that direct port is a better way to distribute the juice, as well as make an even and safer ride. also it is true that single port will put slightly more strain on #1 cylinder than the others, but this isnt totally the case with the ZEX kit. because the ZEX kit regulates the boost, it has a manual shut off if you start running too lean or are over boosting. not to say ZEX is the best, but it is far supiorer to other single port systems, not to mention a fraction of the cost to do a whole dpi system. i say start with the zex and if you find it insuficiant then uprade. id be suprised if you couldnt get one for what you sell the jrsc for. unless its busted, then good luck
Old Apr 28, 2003 | 02:57 PM
MooreBoost's Avatar
Default Re: (sharkey65a)
Im not gonna spray with my SC, if I sell it then Ill spray. Im leaning towards Zex, DP is alot of work, and more to go wrong. I wont be sprayin alot, so Zex makes more sense to me. Now to chose...
Wet or Dry? I wont spray over 75, Ill probably stick with 50 actually.
gmoore
Old Apr 28, 2003 | 02:58 PM
untitled's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sharkey65a &raquo;</TD></TR><TR><TD CLASS="quote">yes its true that direct port is a better way to distribute the juice, as well as make an even and safer ride. also it is true that single port will put slightly more strain on #1 cylinder than the others, but this isnt totally the case with the ZEX kit. because the ZEX kit regulates the boost, it has a manual shut off if you start running too lean or are over boosting. not to say ZEX is the best, but it is far supiorer to other single port systems, not to mention a fraction of the cost to do a whole dpi system. i say start with the zex and if you find it insuficiant then uprade. id be suprised if you couldnt get one for what you sell the jrsc for. unless its busted, then good luck</TD></TR></TABLE>
great advice. i couldnt have said it any better!
KooK
Jul 9, 2003 03:35 PM
hites_05
Jul 7, 2003 11:33 PM
civicmark
Jul 7, 2002 08:20 PM
B19CivicHB
May 15, 2002 05:21 PM
