Nissan Turbo help needed
Just bought a Nissan 300zx T3 turbo off ebay and it doesn't have the internal wastegate acuator.
Anyone know where i can get one? or can i use a universal wastegate?
thanks
thanks
Re: (integraracing91)
You'll be wanting to find a stock wastegate actuator then.
Also, if you take the o2 housing off, you can inspect the wastegate flapper are and check its condition, along with the exhaust wheel. You'll either be making a downpipe off the o2 housing, or off the exhaust side of the turbo... so o2 on or off.
Re: (splitime)
So I can't use the Turbonetics wastegate? if I have to get a stock one where would be the best place to get one. Can I order one off of a nissan parts site?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraracing91 »</TD></TR><TR><TD CLASS="quote">So I can't use the Turbonetics wastegate? if I have to get a stock one where would be the best place to get one. Can I order one off of a nissan parts site?</TD></TR></TABLE>
You could use the turbonetics... but you'll need a manifold that supports an external wastegate... and welding the internal one shut.
You might be able to get it from a nissan dealership... i'd suggest ebay or junkyards though.. maybe even http://www.homemadeturbo.com. you currently have "half" the wastegate... the flapper/exhaust release and you are missing the actuator and rod that is with it.
man I have that exact wastegate off of that turbo you are looking for. Im using an external wastegate so no need for it. The wastegate if off that turbo pictured, the 300zx nissan t3. Let me know if you want it by e-mailing me at fastcivicboy@hotmail.com. My pm's on here dont work. -Nick
Re: (fastcivicboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AccidentproWn »</TD></TR><TR><TD CLASS="quote">just out of curiousity what are the specs on that turbo? are they 60 trims?</TD></TR></TABLE>
All that was said on eGay was that it has a .63 Exhaust A/R
How can I tell what trim it is? let me know and i'll look
I had two different styles of wastegates off that same turbo as well, I had the exact one pictured and a smaller nissan one that will clear better in a honda. They both use a proprietary nissan 5 bolt flange unlike any other t3 so you need one of these two. If you are interested i can see if I still have them, they may have been thrown away.
Re: (DaX)
Thanks, I will do that if these two gentlemen can't come up with a wastegate for me
Also does anyone know what the vacuum diagram is so that when i get a wastegate I install it correctly
Who is Mr Robot?
Re: (Hybrid-Performance.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid-Performance.com »</TD></TR><TR><TD CLASS="quote">Getting a HKS Actuator for a stock S13 or S14 SR20 turbo might work in your case.
Considering it should be the same T25 turbo</TD></TR></TABLE>
but its a t3, not a t25. also, all of the 300zx turbos were 60tirm turbos. with a .63ar exhaust housing
Re: (splitime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime »</TD></TR><TR><TD CLASS="quote">bump for you looking for stuff... instead of bumping for it </TD></TR></TABLE>
Bump .... searched for vacuum diagrams .. couldn't find anything
