NEWBIE going Boost EG6 help ?!?!
Old Apr 13, 2006 | 03:32 PM
VTECth1s's Avatar
Default NEWBIE going Boost EG6 help ?!?!
This my first time ever to have, even drive or have in depth detail knowledge of a turbo kit, I have a built LS/VTEC B18B/B16A that can support 14lbs, could i get any named brand turbo kit that specifically says "B-series Turbo kit", i assume that means it will fit onto any b-series motor. Or do i have to piece together a custom turbo kit?!? help, i need to go boooost!!!
Old Apr 13, 2006 | 03:53 PM
zerovandez's Avatar
Yes, buy a b series turbo kit. It should fit fine, maybe a lil modificaitons needed. I don't have a turbo yet but I plan on putting together my own kit. Maybe someone can prove otherwise?
Old Apr 13, 2006 | 04:02 PM
VTECth1s's Avatar
Default Re: (zerovandez)
yah nice, pretty excited to go boost.
Old Apr 13, 2006 | 04:12 PM
zerovandez's Avatar
But I don't know which kit is able to produce 14lbs of boost. You might wanna snoop around a little bit more....
Old Apr 13, 2006 | 04:14 PM
N20civicB18's Avatar
Peakboost
Old Apr 13, 2006 | 04:41 PM
VTECth1s's Avatar
not a turbo kit that produces 14lbs im saying my engine is capable of supporting up to 14lbs, correction, sorry. What brand is good, reliable and affordable, other then a slightly used turbo kit.
Old Apr 13, 2006 | 07:01 PM
NumberB's Avatar
Default Re: NEWBIE going Boost EG6 help ?!?! (V8-eater)
turbo kits are very good however the biggest advantage to piecing your own together is that you get exactly what you want. however most kits come with the little things which is very helpful if you dont know what you need. you shouldnt rush into it, read into what is needed and about the parts and you might get a better idea of which route you wish to go.
Old Apr 13, 2006 | 07:03 PM
VTECth1s's Avatar
Default Re: NEWBIE going Boost EG6 help ?!?! (milb16a)
THANKS!! , what turbocharger would you suggest that can produce 250-300whp? thanks!
Old Apr 13, 2006 | 07:57 PM
delslo93's Avatar
t3/t4 50 trim or 57 trim should be fine for those goals. I would def. read up on the topic of force induction before jumping into this too like previously stated. Just sit on Honda-tech for hours at a time reading and looking at other peoples set ups. That will def. help you when you go to turbo yours. Good Luck
Old Apr 14, 2006 | 02:57 PM
VTECth1s's Avatar
Default Re: NEWBIE going Boost EG6 help ?!?! (delslo93)
T3/T04E 60trim .63AR i think, is what my builder told me that my engine was built to run good with, what difference is it from the 50 or 57 trim?
Old Apr 14, 2006 | 05:04 PM
Mugencrxsir1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by milb16a &raquo;</TD></TR><TR><TD CLASS="quote">turbo kits are very good however the biggest advantage to piecing your own together is that you get exactly what you want. however most kits come with the little things which is very helpful if you dont know what you need. you shouldnt rush into it, read into what is needed and about the parts and you might get a better idea of which route you wish to go. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delslo93 &raquo;</TD></TR><TR><TD CLASS="quote">t3/t4 50 trim or 57 trim should be fine for those goals. I would def. read up on the topic of force induction before jumping into this too like previously stated. Just sit on Honda-tech for hours at a time reading and looking at other peoples set ups. That will def. help you when you go to turbo yours. Good Luck</TD></TR></TABLE>
HONDA_japan
Sep 29, 2008 07:38 AM
infamouskillas
Apr 9, 2008 09:35 PM
98stylels
Honda Civic (2001 - 2005)
Apr 5, 2006 09:14 PM
do what
Sep 27, 2005 08:40 AM
