New wastegate question
Old Mar 9, 2014 | 03:18 PM
4gencivicef9's Avatar
Default New wastegate question
I have gotten a new tial wastegate.
it has ports for vaccum and water do I need to use these or can I cap these off? also there wasnt enough caps or plugs to seal all the holes. Will they leak pressure?
sorry for the newbie question
Old Mar 9, 2014 | 03:33 PM
turbohatch96y7's Avatar
Default Re: New wastegate question
You must have the mvs. Yes you should hook up the water lines to the wastegate body.
Old Mar 9, 2014 | 03:41 PM
NotARaCist's Avatar
I never narc'd on nobody!
I'm curious - why does a wastegate need cooling?
Old Mar 9, 2014 | 03:45 PM
1158's Avatar
I believe the wastegate cooling is for race applications where the diaphram can melt. I have been running mine without the cooling ports hooked up as a DD for several years with no issues.
Old Mar 9, 2014 | 05:11 PM
They get a little hot...
Old Mar 9, 2014 | 05:14 PM
This ones better
Old Mar 9, 2014 | 05:33 PM
TheShodan's Avatar
Moderator
Ah yes, you're showing the MV-SA (A= AIR) version that was released. The definitive signs are the cooling fins that are between the valve body (exhaust port) and the upper body where the diaphragm is placed. It was TiAL's answer to those that didn't run the water lines for higher endurance racing such as HPDE and Time Attack events.
Old Mar 9, 2014 | 05:54 PM
NotARaCist's Avatar
Holy ********. Maybe if I had thought about the wastegate as an extension of the exhaust, I would have realized that it totally makes sense.
Old Mar 9, 2014 | 07:25 PM
were all noobs at one point
Attachment 526568
Old Mar 9, 2014 | 08:48 PM
NotARaCist's Avatar
Yeah yeah. We also all have our specialties. I (evidently) know too much about fueling and wiring for my own good but hey, that's the beauty of a forum - put all of our minds together, and we could build the most badass "perfect" setup known to man!
Side note: My inbox is suspiciously empty...
Old Mar 11, 2014 | 04:18 AM
wantboost's Avatar
Who is Mr Robot?
I'll be pm'ing you shortly lol
if you have the mvs it really needs the water lines hooked up given the compact design of the gate... given the tops proximity to the valve body, especially if the car is driven hard.
Old Mar 11, 2014 | 01:17 PM
NotARaCist's Avatar
Oh no, I was talking to turbohatch. He has something I want...
Old Mar 11, 2014 | 01:26 PM
Muckman's Avatar
Moderator in Chief
From the manufacturer's website
Old Mar 11, 2014 | 01:27 PM
Today is d day for sure, mang.
I WILL NOT FORGET!
Old Mar 11, 2014 | 01:36 PM
TheShodan's Avatar
Moderator
Only picture of my waterlines hooked up. I used the old lines that were used for the turbocharger (Throttle body and water coolant pipe), I went from -6AN to -4AN.
Then I used a B&R fittings coolant waterline kit to supply water to the turbocharger by the block plug adapter.
86crxintheworks
Jul 18, 2009 09:29 AM
ef dino
Sep 16, 2007 10:21 PM
sydag5
May 16, 2003 10:20 AM
turbospool
Feb 19, 2003 09:10 PM
