Water to wastegate and water to turbo
So I have water lines connected to the drain on my koyo and the block plug fitting on the front of the motor. What I was wondering was what is the easiest way to get water lines to the gate? Should I just run 2 y fittings on the lines I already have or is there somewhere else that I could tap into. I'd rather not use y fittings since they're fairly expensive and my lines are -6 an which is way larger then what the gate needs so then I'd also need reducers. Thanks
