New spring type LMA's
Old Oct 11, 2012 | 10:02 AM
Boyle.R's Avatar
Default New spring type LMA's
Wasn't getting much help over in the "all motor" section so said i'd ask in here
Basically can anyone confirm if the new spring type LMA's will fit a type r head?
Part no.14820-PCB-305
I had a look on autodynamics-honda and it says they are only for non type r B series
http://www.autodynamics-honda.com/hopclomoas.html
Old Oct 11, 2012 | 01:52 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: New spring type LMA's
Here is what you want -
14820-P73-J01
$36 a piece...
Old Oct 11, 2012 | 02:11 PM
Boyle.R's Avatar
14820-P73-J01
$36 a piece...
Thanks for reply. So the spring type is definitely not a option?
Old Oct 11, 2012 | 02:13 PM
nealnanoHX's Avatar
Yes they will work so will the H22 LMA springs with a .040 shim.
Old Oct 11, 2012 | 02:20 PM
B and B's Avatar
Loved
Community Favorite
I used the Prelude lma...$8.xx ea. with stainless washers underneath for spacers..
no problems for 2 yrs... constant 8~9k shifts and occassional over-revs..lol
http://www.hondapartsunlimited.com/o.../14820-pcb-003
Old Oct 11, 2012 | 02:21 PM
Boyle.R's Avatar
Would it be a wiser choice to get the spring type and shim over the older type lma's? Also is there anywhere online you can buy the shims?
Old Oct 11, 2012 | 02:23 PM
B and B's Avatar
Loved
Community Favorite
Home Depot ^^
Old Oct 11, 2012 | 02:47 PM
nealnanoHX's Avatar
Yep most people just use a 8mm stainless washer under the spring. I made some spacers out of hardened tooling steel because I have seen cheap washers get smashed by the force of the spring.
Old Oct 11, 2012 | 02:53 PM
Boyle.R's Avatar
8mm as in to accept a 8mm bolt? As .040" is only a little over 1mm! hardly anything when you think of it. I found a company that should be able to make these up so i'll get 8 of the spring type ordered
97CWITR
Jan 10, 2018 06:38 PM
Boyle.R
15
Apr 6, 2013 07:25 AM
mario_pic
Apr 27, 2009 10:44 AM
IgnitionZ055
Suspension & Brakes
Feb 23, 2009 06:50 PM
Osokwik
Mar 9, 2004 06:45 AM
