New Setup + Dyno numbers
Old Jun 16, 2005 | 11:05 PM
  #26
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: New Setup + Dyno numbers (Jordo@KAP)
Jordo,
with all due respect, there comes a time when you will have to stop swaping out so many parts. You are almost as hard as a women to please. Again, no disrespect just advice from an old guy...
art
Old Jun 16, 2005 | 11:32 PM
  #27
flip1199's Avatar
Default Re: New Setup + Dyno numbers (Arturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">Jordo,
art</TD></TR></TABLE>
Agreed...
I wanna see this run already. I swear this is like his 4th or 5th badass setup. i wanna see some high boost number and track times..
Old Jun 17, 2005 | 12:18 AM
  #28
uglyasscivic's Avatar
Default Re: New Setup + Dyno numbers (flip1199)
OMFG! I just had a crazy thought, Why did you swap from the best manifold on the market to whatever that thing is? If there is one thing I dont like about the lovefab manifolds it has to be the outlet flanges. Have you measured the outlet size vs a T4 inlet. WTF! How could that be better?
Old Jun 17, 2005 | 01:35 AM
  #29
Tinker219's Avatar
Default Re: New Setup + Dyno numbers (uglyasscivic)
must not be hurting much if power was still made Reguardless, we can do whatever flange the customer chooses. Making another one right now that uses a dedicated T4 flange, only T4 holes.
If power is down from where it "should" be with the T3 outlet size, we will swap the manifold out to see if the power is back up to par. My predictions are that the power will be very nice!
Also, if Jordo ran a 4" exhaust, Im sure the benefits would be even nicer. As it sits, the 4" downpipe flares back down to 3", out a Thermal exhaust. Some argue this increases velocity, etc, but from what Ive learned through my 3 years here is bigger is better
Old Jun 17, 2005 | 02:38 AM
  #30
deca's Avatar
Default Re: New Setup + Dyno numbers (Tinker219)
may i ask, what does having 2 wastegate do?
Old Jun 17, 2005 | 02:52 AM
  #31
Tinker219's Avatar
Default Re: New Setup + Dyno numbers (deca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deca &raquo;</TD></TR><TR><TD CLASS="quote">may i ask, what does having 2 wastegate do?</TD></TR></TABLE>
Allow the manifold to evacuate enough energy to slow the turbo down enough to NOT spike to 14psi when youre trying to run only 7psi. This is a bad thing if you care about low boost...
Old Jun 17, 2005 | 03:58 AM
  #32
tony1's Avatar
Default Re: (Jordo@KAP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jordo@KAP &raquo;</TD></TR><TR><TD CLASS="quote">Jordo from kohlerperformance.com tuned it. </TD></TR></TABLE>
Do you always refer to yourself in the third person? lol
Old Jun 17, 2005 | 04:35 AM
  #33
PM-Performance's Avatar
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">
Do you always refer to yourself in the third person? lol</TD></TR></TABLE>
hahaah I was gonna say something about that
I agree with the not worth the change.
Is the boost holdig now though with just one wastegate?
Old Jun 17, 2005 | 04:48 AM
  #34
m R g S r's Avatar
Default Re: (tony1)
lol.....props for tuning it jordo
post some car shots!
Old Jun 17, 2005 | 05:24 AM
  #35
SPOOLINmatt's Avatar
Default Re: (m R g S r)
9 psi and 350whp, what the **** is your compression
props to you
Old Jun 17, 2005 | 05:52 AM
  #36
Alberto's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tinker219 &raquo;</TD></TR><TR><TD CLASS="quote">must not be hurting much if power was still made Reguardless, we can do whatever flange the customer chooses. Making another one right now that uses a dedicated T4 flange, only T4 holes.
Lovefab
Old Jun 17, 2005 | 06:16 AM
  #37
fullracegsr's Avatar
Default Re: New Setup + Dyno numbers (Alberto)
he did also go from a t3 turbo to a t4...
so even that little that he did gain was probably from the turbo........
Old Jun 17, 2005 | 07:21 AM
  #38
Drag_On's Avatar
This is a weird post.. Yes Jordan - you got love from H-T.. But you complain about being broke and not being able to finish your set up etc, then your swapping parts out like a mother. I dont understand why switch from a T3 to a full T4 with a .58? Whats the theory?
Anyways - it looks good, I hope the tune that you put on it is good. Good luck - keep us updated.
Old Jun 17, 2005 | 09:49 AM
  #39
done's Avatar
Default Re: (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">hahaah I was gonna say something about that
Is the boost holdig now though with just one wastegate?</TD></TR></TABLE>
holds 5psi, what the springs is.
Old Jun 17, 2005 | 09:53 AM
  #40
done's Avatar
Default Re: (jerseykid609)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jerseykid609 &raquo;</TD></TR><TR><TD CLASS="quote">well, at least its not blown up. yet
For a guy who less then a year ago complained about having limited money you sure are changing parts alot. </TD></TR></TABLE>
alot can change in a year. I now relie on myself rather then others. I tune my car, i do all the mechanic work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jerseykid609 &raquo;</TD></TR><TR><TD CLASS="quote">well, at least its not blown up. yet </TD></TR></TABLE>
why dont you let me worry about that?
Old Jun 17, 2005 | 09:57 AM
  #41
Chip's Avatar
Default Re: (SPOOLINmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOOLINmatt &raquo;</TD></TR><TR><TD CLASS="quote">9 psi and 350whp, what the **** is your compression
props to you</TD></TR></TABLE>
I think 9:1
Oh, my bad. It must be like 11:1 for it to make good power like that
Old Jun 17, 2005 | 10:04 AM
  #42
done's Avatar
Default Re: (Chip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chip &raquo;</TD></TR><TR><TD CLASS="quote">I think 9:1
Oh, my bad. It must be like 11:1 for it to make good power like that </TD></TR></TABLE>
Old Jun 17, 2005 | 10:05 AM
  #43
done's Avatar
Default Re: (Chip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chip &raquo;</TD></TR><TR><TD CLASS="quote">None of these picture's your trying to show are working </TD></TR></TABLE>
refresh
  #44
Chip's Avatar
Yeah
Old Jun 17, 2005 | 10:09 AM
  #45
TA Performance's Avatar
nice numbers.. question about the top mount manifold, will the manifold crack or break due to so holding up that heavy turbo? is that manifold reliable and how much did you get it for?
Old Jun 17, 2005 | 10:10 AM
  #46
HitEm'Up's Avatar
very nice!!
Old Jun 17, 2005 | 10:21 AM
  #47
99_GS-T's Avatar
The collector looks weird on that manifold. It looks like #2 and #3 come it at like a 15 degree angle ACROSS the collector. Are there any better pictures that show the collector angle more clearly?
I'm running the same turbo in my car. It reacts about the same way as it looks on your dyno chart where it doesn't do much until about 200 RPM before it gets to full boost, then it hits all at once. I like it, but I definitely see it being a restriction and I plan to go up a size or two after getting a dyno run in on it.
Also, you changed A/Fs quiet a bit between the "low" boost pulls (even though they are both way low boost anyway).
Old Jun 17, 2005 | 10:43 AM
  #48
done's Avatar
Default Re: (99_GS-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99_GS-T &raquo;</TD></TR><TR><TD CLASS="quote">The collector looks weird on that manifold. It looks like #2 and #3 come it at like a 15 degree angle ACROSS the collector. Are there any better pictures that show the collector angle more clearly?
Also, you changed A/Fs quiet a bit between the "low" boost pulls (even though they are both way low boost anyway).</TD></TR></TABLE>
also, this was a test manifold.. there is always improvement after the 1st one.
edit: this manifold was actually to my spec also. I wanted to try some theroies to see if i could improve spool up time. Lovefab just made it for me.
Old Jun 17, 2005 | 11:30 AM
  #49
G
sh!t happens.
Nice man... You change turbo parts so much
Old Jun 18, 2005 | 03:31 PM
  #50
Drew Peacock's Avatar
Default Re: New Setup + Dyno numbers (G"UNIT)
Your a mad man. Good job on tuning yourself that is impressive. I guess changing out so many setups will definitely give you first hand experience which is a good thing if you are selling products.
Just don't go pleading poverty anytime soon.
Modified by turbozxi at 6:44 PM 6/18/2005
