New Setup + Dyno numbers
Old Jun 16, 2005 | 09:59 AM
done's Avatar
Default New Setup + Dyno numbers
all done, hater time.
Modified by Jordo@KAP at 11:18 AM 6/19/2005
Old Jun 16, 2005 | 10:05 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: New Setup + Dyno numbers (Jordo@KAP)
the pic of the top mount doesn't work
Old Jun 16, 2005 | 10:20 AM
Alberto's Avatar
Default Re: New Setup + Dyno numbers (wantboost)
Really impressive.
Old Jun 16, 2005 | 10:24 AM
Professor15's Avatar
Looks nice
Old Jun 16, 2005 | 10:27 AM
11psiTurboSI's Avatar
Default Re: New Setup + Dyno numbers (Alberto)
Not a huge difference.
Old Jun 16, 2005 | 10:28 AM
Justin Olson's Avatar
Looks really nice. No boost creep with that design
Old Jun 16, 2005 | 10:36 AM
Alberto's Avatar
Default Re: New Setup + Dyno numbers (11psiTurboSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 11psiTurboSI &raquo;</TD></TR><TR><TD CLASS="quote">Not a huge difference.</TD></TR></TABLE>
Going from 21.5Whp/Psi to 23.7Whp/Psi not impressive to you?
Old Jun 16, 2005 | 10:38 AM
done's Avatar
correct, its not a huge difference, when i crank the boost up on race gas, itll make a bigger difference. but overall, not much change at all.
Old Jun 16, 2005 | 10:42 AM
Suprdave's Avatar
That's pretty wack that you went to a Top-Mount T4 Mani and a Full T4 and picked up 15whp...Goddam Full-Race Products are well built!!!!! You new setup will probably shine at higher boost levels tho...
Old Jun 16, 2005 | 10:45 AM
done's Avatar
Default Re: (Suprdave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave &raquo;</TD></TR><TR><TD CLASS="quote">That's pretty wack that you went to a Top-Mount T4 Mani and a Full T4 and picked up 15whp...Goddam Full-Race Products are well built!!!!! You new setup will probably shine at higher boost levels tho...</TD></TR></TABLE>
yes, nothing is wack, i wanted the higher potential. the t4 turbo is pretty small.
stage 5 wheel, .58 turbine housing
Old Jun 16, 2005 | 10:48 AM
turbo*s2k's Avatar
Should make a huge difference when you turn up the boost.
Old Jun 16, 2005 | 11:43 AM
Makdaddynuge's Avatar
yeah, can't wait for those race gas numbers
Old Jun 16, 2005 | 06:08 PM
done's Avatar
guess i get no love anymore
Old Jun 16, 2005 | 06:11 PM
M.A.R.C.'s Avatar
also not the weather conditions when he dynoed the old setup vs the new
Old Jun 16, 2005 | 07:32 PM
Default Re: New Setup + Dyno numbers (M.A.R.C.)
When did lovefab start making that manifold. I imagine the cost of the lovefab setup is less then full-race also. I it only needs one 44mm wastegate to properly control boost.
This is a step in the right direction if you ask me.
Are you running full 4" exhaust now Jordo?
Old Jun 16, 2005 | 07:37 PM
Turbocivic94's Avatar
Nice setup jordo. I like lovefab product
Old Jun 16, 2005 | 07:41 PM
Tchleung's Avatar
IMO with all the moeny spent and moeny losing from selling your old stuff cheaper then you paid for. I don't grant it being worth it. Sure you will have more pwoer when you turn up the boost vs turnnig up boost on the t3/67 setup but really. Was it worth all the money when you coulda just turned up the boost on the t3/67 and most likely been more then happy with the powerband?
Just my thoughts, cause I rememebr reading your earlier threads and you seemed to always kinda be tight on cahs jsut trying to build a setup.
Old Jun 16, 2005 | 07:51 PM
97turbols's Avatar
I don't know if you are trying to make a comparison between the two manifolds, but this is far from a valid comparison. There are way to many variables in this test to even draw a conclusion.
Old Jun 16, 2005 | 08:18 PM
SL0WEGG's Avatar
Default Re: New Setup + Dyno numbers (97turbols)
doesnt seem like he's saying lovefab&gt;fullrace if thats what your getting at. he's just showing what his new setup is making compared to his old
Old Jun 16, 2005 | 08:40 PM
97turbols's Avatar
Default Re: New Setup + Dyno numbers (boostedej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedej1 &raquo;</TD></TR><TR><TD CLASS="quote">doesnt seem like he's saying lovefab&gt;fullrace if thats what your getting at. he's just showing what his new setup is making compared to his old</TD></TR></TABLE>
that's what I thought the point of this was, if I am wrong ignore my posts.
Old Jun 16, 2005 | 09:28 PM
uglyasscivic's Avatar
Can you post up RPM vs Hp instead of Speed vs Hp. I think you will be dissapointed when the .58ar becomes a restriction.
Old Jun 16, 2005 | 09:35 PM
Bulldogg83's Avatar
Who did the tuning?
Old Jun 16, 2005 | 09:37 PM
done's Avatar
Default Re: (Tchleung)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97turbols &raquo;</TD></TR><TR><TD CLASS="quote">I don't know if you are trying to make a comparison between the two manifolds, but this is far from a valid comparison. There are way to many variables in this test to even draw a conclusion. </TD></TR></TABLE>
Where do you see lovefab manifold vs fullrace manifold?? this post is to generally show old setup vs new.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bulldogg83 &raquo;</TD></TR><TR><TD CLASS="quote">Who did the tuning? </TD></TR></TABLE>
Jordo from kohlerperformance.com tuned it.
Old Jun 16, 2005 | 09:51 PM
done's Avatar
Default Re: (Jordo@KAP)
w
Old Jun 16, 2005 | 10:11 PM
powerofdreams8's Avatar
Two 44mm wastegates to control 9.5psi is ridiculous.
