New Emissions Tests Using OBDII port
Old Jun 21, 2002 | 09:27 AM
VTECPWR's Avatar
Default New Emissions Tests Using OBDII port
I just found out in GA that they are using the OBDII port as part of the emissions testing. Not only can you fail due to what is stored in memory, but if there is not enough data in memory you will fail also. I guess that rules out any stand alone for those of us with OBDII in GA.
Old Jun 21, 2002 | 09:33 AM
JPowers's Avatar
Default Re: New Emissions Tests Using OBDII port (VTECPWR)
How can they do that? What if you were without power and changed your battery and data was lost? After you fail, then what? Do you drive around until you accumulate enough data? That doesn't make sense.
Old Jun 21, 2002 | 09:59 AM
HXMan's Avatar
If you reset your ECU before you go thru the testing station some readiness monitors will not be set, and you will fail.
Old Jun 21, 2002 | 10:58 AM
dustin's Avatar
Default Re: New Emissions Tests Using OBDII port (HXMan)
'95 and earlier cars own
prowd owner of '95 gsr and '88 crx si
Old Jun 21, 2002 | 11:11 AM
Etylorcen's Avatar
Default Re: New Emissions Tests Using OBDII port (dustin)
Tell me about it...gotta pay 200 bucks for an obd2 - obd1 harness for hondata
sgT's Avatar
sgT
Time to go down to the DMV and tell them to change the year on my registration to 1995
Old Jun 21, 2002 | 11:23 AM
Austin's Avatar
Default Re: New Emissions Tests Using OBDII port (sgT)
Now that would be an acclomplishment...gotta love your humor steve
Austin
dragnGSR's Avatar
I've heard about this too. This sucks because I just moved up here to Atlanta, GA. I have a 99' GSR with an OBDII to OBDI conversion. So it's looking like I'm going to have to convert back to OBDII. I guess it's alright considering I can run OBDII on the EFI PMS.
Old Jun 21, 2002 | 07:51 PM
VTECPWR's Avatar
Default Re: New Emissions Tests Using OBDII port (dragnGSR)
I had wanted to run Hondata, but looks like with this test I am SOL. Now I have to go piggyback.
Yes, if there is not enough data in the ECU you fail. They tell you to drive around for a couple of days and come back. Pisses me off that I can run cleaner than most of the **** out there but now if I don't have enough data in the ECU I fail, no matter what my scores are. How about doing something useful and cleaning up diesel cars and trucks. Nothing like being behind a city bus and coughing up a long from the cloud of soot.
Old Jun 22, 2002 | 09:06 AM
HXMan's Avatar
Yea it is gay. One time I took an optional emission test with a CEL, and I passed PERFECTLY. Then, when I went in to take my official test I failed because of the CEL, and they wouldn't actually test my car. I told them it would pass the sniffer, but they wouldn't let me go that far.
Once I did get the CEL fixed, all I need to do was pass the computer test and I passed completly!
Old Jun 22, 2002 | 09:09 AM
Arturbo's Avatar
Better than steak
25 Year Member
Im glad I live in dirty air texas.
art
Old Jun 22, 2002 | 09:30 AM
TurboInteg95's Avatar
CA will probably be following GA soon to. Oh well, glad I have a 95
Old Jun 22, 2002 | 10:14 AM
TheShocker's Avatar
Preach on!
FliiBoii
Nov 19, 2011 06:28 PM
aznwash3wboi
Jul 6, 2009 04:43 PM
Blackhalo6
Dec 3, 2008 07:07 PM
Todd00
Jun 11, 2007 08:39 PM
[ iLL ] iNt3GrA
May 14, 2006 12:32 AM
