New Downpipe pics!!!
Old Mar 29, 2004 | 07:10 PM
TurboJesse
Guest
Posts: n/a
Default New Downpipe pics!!!
Had Jeff (boosted hybrid) fab me a new DP since they don't make any for my special manifold (other than the SSautochrome 2" needle dick one)
Old Mar 29, 2004 | 07:11 PM
USDM 4G VTEC's Avatar
Default Re: New Downpipe pics!!! (Mpir3)
looks good
damnit i need to get mines done
Old Mar 29, 2004 | 07:23 PM
HybridKOOP's Avatar
Default Re: New Downpipe pics!!! (USDM 4G VTEC)
Looks good... no clearence for A/C mount?
Old Mar 29, 2004 | 07:25 PM
n2o_2k's Avatar
looks good. Can't wait to get mine done !!
Old Mar 29, 2004 | 07:30 PM
hulkhb's Avatar
Default Re: New Downpipe pics!!! (n2o_2k)
toght
Old Mar 29, 2004 | 07:45 PM
TRE_'s Avatar
Default Re: New Downpipe pics!!! (hulkhb)
looks nioce
Old Mar 29, 2004 | 09:41 PM
turtle-eg's Avatar
Nice downpipe... but how are you going to run your charge pipe? Is it going through a 90 degree turn from the turbo and then inbetween the turbo and downpipe? Also, what turbo is that, it's not the ssautochrome turbo is it?
Old Mar 29, 2004 | 09:57 PM
el arbi's Avatar
Default Re: New Downpipe pics!!! (turtle-eg)
Crazy
Old Mar 29, 2004 | 10:02 PM
ATS*Mark's Avatar
OG triple OG
Default Re: New Downpipe pics!!! (99SiRacer)
looks nice , is that the SS turbo mani? is it crooked??
Old Mar 29, 2004 | 10:09 PM
calib17a's Avatar
I like that there isn't such a tight radius on the first bend off the exhaust flange. That should help with the velocity of air and spool up.
Old Mar 29, 2004 | 10:35 PM
Hoosier Daddy's Avatar
Default Re: New Downpipe pics!!! (calib17a)
holy huge downpipe!
Old Mar 29, 2004 | 10:54 PM
yellow blur's Avatar
Default Re: New Downpipe pics!!! (Hoosier Daddy)
What type of material is that DP?
Old Mar 29, 2004 | 11:08 PM
roydogg's Avatar
Default Re: New Downpipe pics!!! (yellow blur)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellow blur &raquo;</TD></TR><TR><TD CLASS="quote">What type of material is that DP?</TD></TR></TABLE>
CLick the link in my sig and find out .
Nice dp
Old Mar 30, 2004 | 04:42 AM
TurboJesse
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turtle-eg &raquo;</TD></TR><TR><TD CLASS="quote">Nice downpipe... but how are you going to run your charge pipe? Is it going through a 90 degree turn from the turbo and then inbetween the turbo and downpipe? Also, what turbo is that, it's not the ssautochrome turbo is it?
Its an SSautochrome manifold, Precision SC61
The charge pipe will run like any other normal setup
Old Mar 30, 2004 | 05:24 AM
SiRkid's Avatar
i wish mine looked like that
Old Mar 30, 2004 | 05:45 AM
FredoSP's Avatar
Default Re: New Downpipe pics!!! (SiRkid)
very nice
Old Mar 30, 2004 | 06:07 AM
TurboJesse
Guest
Posts: n/a
Default Re: New Downpipe pics!!! (FredoSP)
few more pics can't wait to have a real exhaust system instead of a 3" dump
Old Mar 30, 2004 | 07:07 AM
boosted hybrid's Avatar
Default Re: New Downpipe pics!!! (HybridKOOP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridKOOP &raquo;</TD></TR><TR><TD CLASS="quote">Looks good... no clearence for A/C mount?</TD></TR></TABLE>
Jesse isnt running A/C or P/S, so i made the downpipe accordingly. I did leave enough room to retain the side brace mount on the block. There is very little restriction with this downpipe since the arc is gradual, and the downpipe hugs the oil pan to give maximum road clearance.
Old Mar 30, 2004 | 07:11 AM
NuclearB18B's Avatar
Default Re: New Downpipe pics!!! (boosted hybrid)
nice
Old Mar 30, 2004 | 07:13 AM
hoggy's Avatar
Something I've always wondered is with the downpipe going on the drivers side, the chargepipe has to pass fairly close to it. Does this cause raised temps on the charge air?
Old Mar 30, 2004 | 07:15 AM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
i love the ideah.. very nice work..
Old Mar 30, 2004 | 07:16 AM
TurboJesse
Guest
Posts: n/a
Default Re: New Downpipe pics!!! (hoggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hoggy &raquo;</TD></TR><TR><TD CLASS="quote">Something I've always wondered is with the downpipe going on the drivers side, the chargepipe has to pass fairly close to it. Does this cause raised temps on the charge air?</TD></TR></TABLE>
Im not 100% sure but i don't think it would be anything noticeable since the charge hasn't been cooled yet.
Old Mar 30, 2004 | 07:51 AM
Bailhatch's Avatar
the oil line also has to cross the DP. I like to mount my turbos the other way just to make it cleaner and to eliminate one 90* bend in the DP for slightly better flow. If you lay it out correctly both ways work fine, just one has a few more thing to watch out for.
Old Mar 30, 2004 | 08:41 AM
legendboy's Avatar
Default Re: New Downpipe pics!!! (Bailhatch)
I still think having the compressor on the drivers side makes for a better flowing downpipe. Not sure how much real world advantage there is
Old Mar 30, 2004 | 09:27 AM
Bailhatch's Avatar
Default Re: New Downpipe pics!!! (legendboy)
thats what i'm spraying. I think the real world advatage is how easy it is to setup and work on. one less bend doesn't hurt either
