New Built Motor...starts..but dies right away...HELP.
I am trying to get mt Built H22 up and running, but am having problems. When I try to start it it starts for about a second and dies. It is getting fuel and is getting spark. The cam timing is dead on. I have adjusted my built head valve lash to factory specs, there is a brand new battery with a full charge, I have oil pressure, and the starter is good, so I am pretty much clueless now as to what is causing it to die, so if anyone could please help I would really appreciate it. Also, I am running n/a just to start it, stock ecu, injectors, header etc just so you know, but has a nice fi setup waiting just to keep it in this forum.
Re: (Zakar)
This is everything that might contribute to the problem:
Stock ECU chip
Stock injectors
Walbro 255hp Pump
MSD SCI Ignition
Blaster SS Coil Portflow Head
Supertech Valvetrain
Skunk2 Cam Gears
Stock Camshafts
Benson's Block
CP 9:1 Pistons
Pauter Rods
OEM Plugs/wires
OEM Dizzy
Stock ECU chip
Stock injectors
Walbro 255hp Pump
MSD SCI Ignition
Skunk2 Cam Gears
Stock Camshafts
Benson's Block
CP 9:1 Pistons
Pauter Rods
OEM Plugs/wires
OEM Dizzy
Re: New Built Motor...starts..but dies right away...HELP. (BB6-213)
this was happenin to my buddys car and it ended up being the valves... needed to be adjusted, it was choking the car and it wouldnt idle..
Maybe you just need to hold the throttle open for a few minutes. When I started one of my LS setups it needed to run for a bit before it held idle.
I will go asjust the valves again, and try the throttle thing, is there anything else that I can check, I have the whole day dedicated to the car and I really want to get it running.
Re: (aallbbeerrtttttt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aallbbeerrtttttt »</TD></TR><TR><TD CLASS="quote">my buddy recently swapped a b16a2 into a civic, and it would die right away if you started it, so he held the throttle open after he started it and revved it a couple times to 4k....
no problem after that</TD></TR></TABLE>
Thanks! I just got the valves adjusted so I am going to go try this, thanks.
Re: (qfast817)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qfast817 »</TD></TR><TR><TD CLASS="quote">do you have a restor box on it?</TD></TR></TABLE>
I am actually running the inline resistors instead of the resistor box.
Re: (BB6-213)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BB6-213 »</TD></TR><TR><TD CLASS="quote">
I am actually running the inline resistors instead of the resistor box.</TD></TR></TABLE>
So you are using stock injectors, stock ecu and resistors inline with your injectors.... that might be the problem.
You can't run saturated injectors with the resistor box or inline resistors.
I am running an OBD1 P72 with an H22 N/A basemap, Stock OBD1 H22 240cc (?) Peak and Hold Injectors, Inline resistors. Will that work?
Its seems as when I leave the car sit for a few mins then try and start it, it will almost run for a second, but when I try to start it again right away it dies faster, so could I possibly be flooding the engine?
I burnt a new basemap for it and it fired right up, tomarrow I will let it run for a bit and liet you guys know whats going on, thanks.
you deffinitly don't wan't to be flooding your new engine, But someone with more insite could correct me, Wouldn't it be possible to wash out the cylinders on a new engine if you flood it?
