new build compression test low
Old Apr 12, 2005 | 05:06 PM
JdmEKCivic's Avatar
Default new build compression test low
My buddy just built his motor with cp pistons (81.5) 9:1 and eagle rods with a cometic head gasket (.40) with a b16 head when we did a compression test on the new motor we got 1-2-3-4- 160-160-160-148 now the engine wasn't very hot just warm, and the throttle was open. on #4 when we added oil it went to 160. the motor has 2 miles on it, would those # go up after the break in? also for some reason the car runs very rich to the point where the plugs are black. the timing is set at 16 and the fuel press is 45 with vac. any ideas? ty
Old Apr 12, 2005 | 05:22 PM
JdmEKCivic's Avatar
Default Re: new build compression test low (JdmEKCivic)
bump
Old Apr 12, 2005 | 06:46 PM
dunkd's Avatar
I believe it takes a little while for the piston rings to fully seal on new motors. Just keep monitoring it and if it doesnt get better after 1500 miles then there is prolly a problem... good luck
Old Apr 12, 2005 | 06:52 PM
JdmEKCivic's Avatar
Default Re: (dunkd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd &raquo;</TD></TR><TR><TD CLASS="quote">I believe it takes a little while for the piston rings to fully seal on new motors. Just keep monitoring it and if it doesnt get better after 1500 miles then there is prolly a problem... good luck</TD></TR></TABLE>
God we hope so hate to do this **** over lol
Old Apr 12, 2005 | 06:54 PM
turbodohcsi's Avatar
it does take a little time for the rings to seat, and when they do your compression numbers will go up. also if you let your car come to normal temps then the numbers should also go up a little bit
Old Apr 12, 2005 | 07:31 PM
JdmEKCivic's Avatar
Default Re: (turbodohcsi)
bump any other ideas?
Old Apr 12, 2005 | 07:33 PM
racinskittle's Avatar
Default Re: (JdmEKCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdmEKCivic &raquo;</TD></TR><TR><TD CLASS="quote">bump any other ideas?</TD></TR></TABLE>
THe rings have to seat. Give it some time, EVERYONE'S BEEN TELLING YOU THIS.
BTW: When you're breaking in your engine you dont want it to run too rich.
Old Apr 12, 2005 | 07:50 PM
JdmEKCivic's Avatar
Default Re: (racinskittle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racinskittle &raquo;</TD></TR><TR><TD CLASS="quote">
BTW: When you're breaking in your engine you dont want it to run too rich. </TD></TR></TABLE>
I know this. I ask more than the ring question thats why i asked for any other ideas FYI
Old Apr 12, 2005 | 09:07 PM
make sure your timing belt is on correctly as well.
Old Apr 13, 2005 | 01:09 PM
dunkd's Avatar
do you have it tuned?
Old Apr 13, 2005 | 04:26 PM
JdmEKCivic's Avatar
Default Re: (dunkd)
not yet he's waiting for after the break in.
Old Apr 14, 2005 | 11:43 PM
crazyitr's Avatar
If you run a motor on a new build rich, the excess gasoline in the cylinders will wash off the oil between the rings and the cylinder walls. It will wear the hone marks off the cylinder walls and cause too much cylinder to wall clearance. As a result your rings will not seal, you will lose compression and burn oil
It is very important to break in a motor with a good base map and turn off the car if it runs in limp mode or runs excessively rich.
Earl had a very good post on this and properly breaking in a motor. You should tow your car to a competant tuner if in doubt before ruining your motor.
Old Apr 15, 2005 | 12:06 AM
adseguy's Avatar
Default Re: (crazyitr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyitr &raquo;</TD></TR><TR><TD CLASS="quote">If you run a motor on a new build rich, the excess gasoline in the cylinders will wash off the oil between the rings and the cylinder walls. It will wear the hone marks off the cylinder walls and cause too much cylinder to wall clearance. As a result your rings will not seal, you will lose compression and burn oil
80% of the break in happens within the first half hour if that. it's very important that you run a god mixture and rev the engine when you are supposed to. Don't start that engine until you get to a tuner. those compression tests mean nothing right now. After about three ours i would check and they should be respectable. GL and let us know what happened
Old Apr 15, 2005 | 07:54 PM
JdmEKCivic's Avatar
Default Re: (adseguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">
80% of the break in happens within the first half hour if that. it's very important that you run a god mixture and rev the engine when you are supposed to. Don't start that engine until you get to a tuner. those compression tests mean nothing right now. After about three ours i would check and they should be respectable. GL and let us know what happened</TD></TR></TABLE>
ok here's an update we turned the fuel press down (39 with vac) and check the valve lash, they were way off. We got the car to idle like a kitten. we didn't do another compression test yet, soon as it's done well post the results.
Old Apr 15, 2005 | 07:57 PM
JdmEKCivic's Avatar
oh by the way the car is running off a tune done by boosted hybrid for my previous setup. I know it's not for this motor but it's a good base map
Old Apr 16, 2005 | 05:38 AM
JdmEKCivic's Avatar
After the last post we did the compression test over and we got 192 across the board. but for some reason somtimes white smoke comesout the exhuast not all the time thats whats weird. and were getting heavy blow by through the breather not smoke but heavy air. the head is rebuilt with new seals. also were running a catch can setup the endyne way.
central_driver
Jul 28, 2010 11:30 AM
vtibrazil
10
May 30, 2008 12:39 PM
zhan28
Feb 23, 2008 07:19 AM
GdmLaz
Jan 28, 2008 04:54 PM
