Need some opinions
Old May 31, 2006 | 11:58 PM
91crxturbo's Avatar
Default Need some opinions
Hey guys, i currently have a b17 turbo setup. I spun a rod bearing. I plan on buidling the motor and was thinking of my options. My first choice was to get a hold of an LS block(build/sleeve it) and use my b16 head(lsvtec turbo). Or I could put in b16 crank/rods(build/sleeve) and make it a b16 turbo....What do you guys think? I am mechanically inclined and have built a couple DSMs, but im kinda new to this Honda thing...I'm am looking for the best bang for the buck and plan on building this motor once correctly without having to worry about it later. Any constructive input would be appreciated!!!
Modified by 91crxturbo at 1:31 AM 6/1/2006
Old Jun 1, 2006 | 09:36 AM
91crxturbo's Avatar
bumpity bump bump
Old Jun 1, 2006 | 09:42 AM
B18 CYA's Avatar
it will most likely cost you about the same for either a b16 or ls block build. LS will give you more torque because of the longer rod/stroke ratio.
Old Jun 1, 2006 | 10:18 AM
91crxturbo's Avatar
Default Re: (B18 CYA)
Thats what i was thinking but would going to an LS setup mean i have to get a bunch of new crap or with the stuff(oil pump etc) from the b17 work?
mra4886
Oct 30, 2006 08:17 PM
deucedeuceEK
11
Feb 5, 2006 07:21 PM
boostedeghatch
May 6, 2005 04:54 AM
