Need some clearification
Old Oct 10, 2010 | 11:57 AM
krazyhmongboi's Avatar
Default Need some clearification
I've searched and I've been seeing different ways to hook up an oil catch can
I already plugged up the breather box hole with a freeze plug and need hook up the hoses now.
can i just run the two prelude fittings to my block and then run hoses to those fittings coming from the two fittings of the catch can?
if that works, i'd just have to plug of the nipple on the intake manifold right?
Ls-vtec turbo motor
Old Oct 11, 2010 | 08:00 PM
Default Re: Need some clearification
Help!
Old Oct 12, 2010 | 10:12 AM
NonovUrbizniz's Avatar
Loved
Yes. You can run it like that and all that's left to do is plug the V/C vent tube and the intake manifold vacum line in nipple.
..but ideally you want a seperate line and fitting for the return line.
Also depending on how much HP you plan on making the 2 lines off the back may not be enough. Most of the name brand high HP Bseries setups have 4 in one out... although on most sub 500hp builds that's probobly excessive.
jwm1986
Feb 9, 2010 12:07 PM
agy2k2
Aug 11, 2006 05:30 AM
messy hatch
Jun 23, 2006 11:32 AM
HamiltonRex
Dec 30, 2005 09:56 PM
Stealthman80
Jul 20, 2005 12:33 PM
