Need Some Advice
Old Sep 16, 2008 | 07:39 PM
CTR_B's Avatar
Default Need Some Advice
So I pulled the oil pan off today and I noticed metal shavings in the pan, Some would stick to a magnet some wouldn't. Im not sure where it came from, Oil pump, bearings or maybe I just didnt clean it good enough after drilling and welding the fitting on for the Return line either way I think its time to move on to a new block.
This guy on H-T said he has a Gsr block that he'll sell me for 175.00 but it has a cracked piston from a valve dropping into cyl 3.
My question to this is: Can I use my B16 P30's on a P72 Crank Rods? Pro's and Con's
Old Sep 16, 2008 | 07:52 PM
95dxsir2's Avatar
Default Re: Need Some Advice (CTR_B)
why don't you take it to a honda dealership and see what they say.
Take a pic of said metal. see if i can help
b18c1 is the same size bore as a b16, so i'm *** uming it will work.
Modified by 95dxsir2 at 8:57 PM 9/16/2008
Old Sep 16, 2008 | 08:00 PM
CTR_B's Avatar
Default Re: Need Some Advice (95dxsir2)
As of now I whiped the pan clean, Cleaned the pick up and put it all back together.
It dosent make and noises but I do have an oil pressure problem. Some reason when the car is at running temp the oil light comes on. Now i was told to install a Manual oil pressure gauge to see if maybe I had a bad sensor or something but the manual gauge concurs with the light. At running temp Im only at about 7-10 psi but when its cold Im about 70 psi. when in driving conditions the oil pressure is normal also. just when its ideling is there a pressure drop. Now this too leads me to belive I either have a bad oil pump or spun a bearing.
Old Sep 17, 2008 | 06:46 PM
CTR_B's Avatar
Update: *****
I dropped the pan today to check the bearings and didn't see anymore metal shavings, Also all the bearing looked good.... Im thinking this is an oil pump issue.
I swapped oil from 10w30 to 20w50 and my oil pressue problem has seem to go away for now, Another thing leading me to the oil pump.
Old Sep 18, 2008 | 03:03 AM
boostedcivicsir's Avatar
Mr. Badwrench
me personally if you are goin as far as to put stock pistons on stock rods you are wasting your time. especially when you are dealing with pressed pins.
if it is out and apart, spend the little extra on a set of good stuff.
do it once.
ShortbusEK
Apr 20, 2008 12:00 PM
ShortbusEK
Apr 5, 2008 02:51 PM
suicide_shift
39
Oct 4, 2007 11:07 PM
AZintegragsrT
Jun 30, 2006 01:26 AM
xsi-t
Nov 27, 2005 04:02 PM
