Need a Quick Spooling Turbo
Old Aug 29, 2012 | 08:41 AM
GEN2 LS's Avatar
Loved
Default Need a Quick Spooling Turbo
Need a small, quick spooling turbo that my motor won't outflow.
motor setup is a bone stock b17, looking a for smaller turbo so I can retain A/C (have a DA chassis and everyone knows they have no ROOM)
I have everything else, just need a turbo. I've had previous experience with Precision's had one take a **** on me after only 1000 miles or so on a brand new unit. So sorta stand offish on purchasing another. Garrett's have never given me issues but their turbos are a bit outta my budget. Anyone have any recommendations? Looking to achieve
full boost by 3000-3500rpms
max power of 275-300whp
really want some low and very strong midrange
retaining stock redline
will be using a goautoworks cast manifold
Old Aug 29, 2012 | 09:37 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: Need a Quick Spooling Turbo
gt28rs... pretty much an all around good performer with awesome response, could make your power goals no problem
Old Aug 29, 2012 | 09:41 AM
kbouchard1092's Avatar
Above, or for a cheaper option Garrett T3/t4oe 50 Trim. Which would give more PEak power then youre goals. The Gt28rs will spool faster tho. Both should give u a decent powerband for the street. But if youre never looking to make much over 300 and money aint a issue def go with above.
Old Aug 29, 2012 | 09:46 AM
GEN2 LS's Avatar
Loved
yeah I wish that was a option but that's outta my budget, trying to spend no more than $600 if I have to buy a brand new turbo.
Old Aug 29, 2012 | 09:52 AM
TheShodan's Avatar
Moderator
Is Go-Autowork's cast manifold made for 5 bolt turbine housing or no?
You'll never get full boost by 3500rpms on a b17 without spending some moolah..regardless of company.. 300whp is very possible, but you don't need full boost pressure by 3000-3500rpms to get midrange torque.
Gotta go above $600 to get it done.. sorry. That will be the key factor on how you'll achieve this.
Old Aug 29, 2012 | 09:57 AM
GEN2 LS's Avatar
Loved
not looking to push much more than 300-330whp range. I intend on keeping the motor together and bone stock as b17's are hard to come by. I've have several past built setups and stock motor setups on E85 etc with larger turbos making 400+hp with a decent amount of lag, cars always got boring to me. I'd rather have a super responsive street car with A/C for once! I have looked at 50 trims I was thinking a .48 housing should suffice for a stock redline, or go .63?
Old Aug 29, 2012 | 10:09 AM
wantboost's Avatar
Who is Mr Robot?
http://www.youtube.com/watch?v=q6RcNur4K4o
Mac makes awesome turbos and this would fit your needs pretty close to your budget
Old Aug 29, 2012 | 10:17 AM
i Would advise against the .48 a/r...DEFINATLY get the .63 a/r
Seems like the 50 trim is youre best bet with youre budget in mind
Old Aug 29, 2012 | 10:21 AM
dcmatt's Avatar
I thought you gave up on turbo hondas lol. Wish I woulda bought the teg shell from you. Good luck on the next project!
Old Aug 29, 2012 | 10:44 AM
GEN2 LS's Avatar
Loved
yeah I thought so too lol:p well the funny thing about me selling the DC was I sold everything so far except 85% of the turbo kit, just no interest for it so instead of letting it waste away I might as well put it on my daily driver. The only part I sold from the kit so far was the Hondata 4 Bar and my Garrett 60-1. I'm trying to keep a strict budget in mind on this car and take the "less is more" approach with the setup. Thanks for the well wishes man!
Old Aug 29, 2012 | 10:55 AM
GEN2 LS's Avatar
Loved
not sure I know it works with 4-bolt housings, i'll have to give Greg a call or maybe he might chime in.
any idea when this turbo would reach full boost on a b17? I talked to you about this unit a few years back.
http://www.atpturbo.com/mm5/merchant...egory_Code=TBN
Old Aug 29, 2012 | 12:47 PM
TheShodan's Avatar
Moderator
Tried a few of those. Those were like 250whp, and not 350whp. They only seemed to work ok as twin applications. Otherwise I gave up on those.
Old Aug 29, 2012 | 02:51 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Yes, yes, and yes... the new manifold design tilts the turbo out further and also, has better wastegate placement.
Here OP, here are some options...
http://www.go-autoworks-store.com/gatuch.html
98tegLSvtec
Oct 22, 2010 12:41 PM
banshee04
Oct 27, 2008 02:11 PM
k_lude
Nov 30, 2006 05:34 PM
Schister66
Dec 10, 2005 09:26 AM
SPOON_BeIgHtEeNsEe
Jan 28, 2004 05:17 PM
