Need quick answer: JE piston in GSR and in LS, which is which...
Old Jul 1, 2002 | 06:22 PM
93LSivic's Avatar
Default Need quick answer: JE piston in GSR and in LS, which is which...
Ok, buying some JE's now. They are stock bore 9.5:1 compression. I believe this is the ratio on the GSR motors. Now, if these are going into my LS it will lower, right?? How much?
Need the answer fast---thanks....
Old Jul 1, 2002 | 06:28 PM
93LSivic's Avatar
Default Re: Need quick answer: JE piston in GSR and in LS, which is which... (93LSivic)
Not quick enough.....c'mon
Old Jul 1, 2002 | 06:32 PM
2K_TEG's Avatar
the b18b has a larger combustion chamber, so yes...9.5 in a GSr should be lower in the LS.
probably leave you with around 9.2:1
Old Jul 1, 2002 | 06:33 PM
2K_TEG's Avatar
Default Re: Need quick answer: JE piston in GSR and in LS, which is which... (2K_TEG)
10 minutes is not good enough???
Old Jul 1, 2002 | 06:37 PM
93LSivic's Avatar
Nope!!
Cool thanks man. I kinda knew it, but just wanted to make sure before i send a paypal payment.
Now let this thread drop to the bottom....
Old Jul 1, 2002 | 06:38 PM
2K_TEG's Avatar
before it drops...
http://www.c-speedracing.com/howto/c.../compcalc.html
crx_0_o
Aug 18, 2006 05:51 AM
fluke83
Sep 10, 2004 12:13 PM
Dustin98lude
Jun 1, 2003 07:21 PM
neket live
Oct 3, 2002 06:34 PM
turboex
Apr 6, 2002 02:35 PM
