Need new Ring Lands...
Old May 5, 2005 | 09:14 AM
PhantomX's Avatar
Default Need new Ring Lands...
Hey guys, just to clarify what ring lands are... is it the ring that looks cracked or the one below it??....I recently had problems with my engine and Im bringing it in to SpoolinPerformance to get it checked out... but if it is damanged ringlands...does it mean I have to replace all my pistons too?
What brand of Ringlands do you guys suggest? thankx
PHOTOBELOW is not my piston....just a pic i pulled from Goodle so I can use it as a reference..
Modified by PhantomX at 1:37 PM 5/5/2005
Old May 5, 2005 | 09:19 AM
mattssi's Avatar
Default Re: Need new Ring Lands... (PhantomX)
ringlands are a part of the piston. They are what the rings set in. When they let go, the rings no longer seal or hold compression. That is why you have to replace the piston. In most cases, if only one piston suffered damage, you could just replace it, but ususally the damage was inflicted to all of them and they all need to be replaced.
Old May 5, 2005 | 09:28 AM
rmcdaniels's Avatar
And that is your ring land that is cracked. You will need new pistons, and the cracked ring land probably scored your cylinder wall, so you will need to get the block bored and honed.
Old May 5, 2005 | 09:39 AM
adseguy's Avatar
Default Re: (rmcdaniels)
damn even looks like your oil control ring cracked . What happened...30* of timing at 20lbs or what?
Old May 5, 2005 | 09:41 AM
dustin's Avatar
I don't think that is his piston... heh.
Old May 5, 2005 | 10:09 AM
PhantomX's Avatar
Default Re: Need new Ring Lands... (dustin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin &raquo;</TD></TR><TR><TD CLASS="quote">I don't think that is his piston... heh.</TD></TR></TABLE>
your right haha its not mine... just grabbed a quick picture from google....Hopefully my pistons and ringlands are fine....going to get it checked out today...
Old May 5, 2005 | 10:31 AM
m R g S r's Avatar
Why are the skirts of the piston not aligned with the hole for the wrist pin? I don't think I've ever seen a piston like that.....
Old May 5, 2005 | 11:00 AM
DaveF's Avatar
Default Re: Need new Ring Lands... (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">Why are the skirts of the piston not aligned with the hole for the wrist pin? I don't think I've ever seen a piston like that.....</TD></TR></TABLE>
your kidding right?
Old May 5, 2005 | 11:44 AM
EJ1 wilcox's Avatar
I dunno... I've never seen one like that either...
Old May 5, 2005 | 11:57 AM
adeihl's Avatar
huh? most pistons ringland bosses are 90degrees to the long side of the skirt.
Old May 5, 2005 | 12:44 PM
J337_UNIT's Avatar
Default Re: (adeihl)
if the ringlands are cracked on the pistons, then you need new pistons... no such thing as replacing ringlands.
Old May 5, 2005 | 12:47 PM
DaveF's Avatar
Default Re: Need new Ring Lands... (EJ1 wilcox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">
I dunno... I've never seen one like that either...</TD></TR></TABLE>
i hope you are kidding......
Old May 5, 2005 | 12:55 PM
EJ1 wilcox's Avatar
Default Re: Need new Ring Lands... (Dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">i hope you are kidding...... </TD></TR></TABLE>
LoL... Why did I think they were the other way?
That piston just looks funny for some reason. I guess it's not because of the wrist pin.
civicrolln
Jun 9, 2009 04:37 PM
Mydogisgone
Mar 9, 2007 08:17 AM
boostincoupe
Nov 10, 2006 07:53 PM
rocket_R
Jun 13, 2006 11:09 PM
Fl_civic_rider
Mar 12, 2004 07:10 AM
