Need Map for S200b
Old Apr 25, 2004 | 06:52 AM
vti2's Avatar
Default Need Map for S200b
the map schoul be for these engine:
B16a2
Bensons Sleeved
84mm bohre
CP pistons 9:1
Pauter rods
Bensons Mikropoloshed and balance cranck
No head work
Supertech valvetrain
Victor X manifold
Full-Race exhaust manifold
3" Downpipe
Fully 3" exhaust
T3-60-1 Stage 5 wheel .82trim turbine .70 AR compressor 4" inlet and 2,5" outlet
880cc Precision injectors
Hondata S200b
3 bar map sensor
Quaige
DSS stage 3
apexi ACVR boost controler
running 22psi
Don“t want to rev more than 9000 rpm
Hondata S200b with p28 ecu OBDI
Walbro 255Lph HP
If somebody hast a similar setup with a good map lease let me know i will pay for it also no probs.
Thanks
Modified by vti2 at 2:43 PM 4/26/2004
Old Apr 25, 2004 | 08:34 AM
TurboTegB18c's Avatar
Default Re: Need Map for S200b (vti2)
You can get a base map made for those, but i don't think you'll find a map where u can drive it hard. I can make u a map that will get you to your tuner. Let me know. Paul
Old Apr 25, 2004 | 10:31 AM
vti2's Avatar
Default Re: Need Map for S200b (TurboTegB18c)
PM you.
Old Apr 26, 2004 | 05:14 AM
vti2's Avatar
UP
Old Apr 26, 2004 | 06:15 AM
tegmech's Avatar
Have you checked hondata's forum? Im not sure if there would be a few bins on there with a similar setup. Also, do you have a burner by chance? because you could burn an uberdata chip for the time being till you get to the tuner.
Old Apr 26, 2004 | 09:33 AM
vti2's Avatar
Default Re: (tegmech)
Yes i have a chip burner that comes with my hondata.
Old Apr 28, 2004 | 07:02 AM
B18Flip's Avatar
Default Re: (vti2)
sent you a PM fredy
Old May 5, 2004 | 08:00 AM
Weedm4n's Avatar
Default Re: (B18Flip)
up
b20turbocivic
Engine Management and Tuning
14
Dec 28, 2009 11:31 AM
i.
Feb 12, 2009 11:50 AM
JDM97R
Jul 22, 2008 09:27 PM
Turbocivic94
Jun 21, 2005 07:32 AM
95c1v1cs1
Apr 15, 2003 12:13 PM
