need lil help in doing oil line
one bit of advice i can give you, is dont put the T on the block itself...
get a seperate line (greese gun line works, suprisingly.) and run the T off that instead
its too much weight with the sender on it.. and it could crack the block...
happened to me, luckily it was only 2 threads.. and i could salvage it
boost doesnt matter at all....
oil lines are oil lines... power goals or boost levels play no part of what to do with the oil lines... they have to be there regardless
i know thanks for the in put guys
but im still want sumthing to make sure im going to be doing it all right (like a diagram or picture) that wud be helpful
