need informed advice on turbo gsr setup!
Old May 29, 2004 | 05:59 PM
evilgsr's Avatar
Default need informed advice on turbo gsr setup!
well the funds are starting to come in and im trying to get a set plan for my gsr i was planning to turbocharge it and also build up the bottom end to handle pretty much whatever i wanna throw at it. Well for the bottom end so far i was planning to stroke it to a 2.0 and run a 9:1 compression ratio with perhaps one of these type kits http://www.importperformancepa....html as for the turbo set up i was going to go with a ball bearing t3/t4 kit from http://www.swift-performance.com and hopefully run in the area of 20 lbs of boost or so at the most(with the built bottom end via that stroker kit) controlled with a hondata s200 system ,well thats my plans so far basically im looking for someone to give me some constructive criticism and maybe a few pointers also some advice on the trim size of the turbo, i plan to use the car basically as a daily driver/weekend warrior i drag race at an 1/8 mile track now and again and auto x monthly any help is greatly appreciated
mastakmk
May 15, 2007 10:00 AM
T3T495GSR
Jul 18, 2005 07:42 PM
1.8tgsr
Jan 20, 2005 01:44 PM
All Motor R
Aug 3, 2002 09:53 PM
[tk4L] Doke
May 15, 2002 05:25 PM
