need ideas
Old Oct 26, 2013 | 04:40 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default need ideas
How would you connect those two if you had no welder and cut-off saw?
Old Oct 26, 2013 | 04:48 PM
Tippyman's Avatar
Default Re: need ideas
You might not need a welder, but a cheap chop-saw would be helpful.
Flex exhaust tubing from autozone? PVC pipe? Lol
Kinda hard to see the angles and whatnot.
Old Oct 26, 2013 | 04:53 PM
aside from the obvious angles you see, the coupler on the right is about 2" higher than the coupler on the left. the entire assembly requires an "S" shaped tube.
no welder nor cut off tool is due to location, i don't have the space for it.
Old Oct 26, 2013 | 11:35 PM
wantboost's Avatar
Who is Mr Robot?
looks like an oem srt-4 intercooler?
unless you can find a pre-made s tube you're pretty much hosed... do you have a local fab guy?
Old Oct 27, 2013 | 01:03 AM
it is an SRT4 intercooler which fits so wonderfully. there are plenty of fabricators around, and i can technically go to my old work place and just use the welder there. it requires, diplomacy.
Old Oct 27, 2013 | 01:05 AM
at this point i am considering a polyimide resin composite tube, and a flex exhaust piping
Old Oct 27, 2013 | 01:11 AM
wantboost's Avatar
Who is Mr Robot?
that could work, not sure how it would like repeated heat and pressure cycles, not to mention vibrations... I see it cracking very very quickly, unless you overbuild it by a factor of like 5 lol.
When diplomacy fails, try using bullets :p
I don't see why a fab shop (other than your old job) wouldn't be capable of doing this in a matter of an hour or two and fairly cheap.. 2 cuts max, 1 weld, bead rolling 2 edges.... should be cheap, especially if you supply materials
I'm still debating using an OEM SRT-4 intercooler on my build but my goals have gone up to 400-425whp. I think the compact size would work better for the aero package I'm building and the required ducting for my oil cooler, trans cooler, brake ducts, etc. Just not sure the OEM could support that level on a road course for 20 minute sessions. I know CX Racing makes a larger core but it's huge all over compared to the OEM
Old Oct 27, 2013 | 02:58 AM
tepid1's Avatar
If you rotate the IC coupler down then you may be able to get away with a 45deg tube. The couplers are flexible. Use that to your advantage.
Old Oct 27, 2013 | 05:49 AM
motoxxxman's Avatar
just rotate the couplers and stick a straight pipe in there. like tepid1 said, the couplers are flexible, they'll bend a bit with no issues.
Old Oct 27, 2013 | 10:48 AM
no, a straight pipe will not work with certainty. it will pinch the couplers too much. however i will try a 45 degree bend alone (i am sceptical about it though)
Gr8DC2R
Welding / Fabrication
Nov 11, 2007 06:45 PM
RuskeR
Feb 4, 2005 11:57 PM
GOLDBERG
Apr 14, 2004 07:37 AM
7thGear
Jan 11, 2004 05:30 AM
jazz215
Jan 25, 2003 05:26 PM
