need help on wiring walbro fuel pump?
Old Nov 3, 2007 | 06:30 AM
RACEPAK's Avatar
Default need help on wiring walbro fuel pump?
sup everyone.
my walbro is currantly wired to the stock relay, and i want towire it with thicker wires like everyone does,
anyone have instructions or can tell me how to do this?
ps, which relay i need?
thanks
Old Feb 10, 2008 | 10:58 AM
jared50438's Avatar
Default Re: need help on wiring walbro fuel pump? (RACEPAK)
use your power wire from your existing fuel pump wiring and use that wire as the 12v signal wire coming ito the relay (to turn relay on and off) and a 20-30 amp relay is fine since most walbro pumps are stamped 20 amp. and then after that get your power from your battery or a constant power source with 13 volts to get the best out of your pump. your stock wire to your pump is about 10.5
boostlsveg
Jul 25, 2014 06:25 PM
LS-VTEC-TURBO-EF9
Sep 8, 2013 03:24 PM
Lmgrcivic
Apr 7, 2010 01:30 PM
Bond
Oct 5, 2009 05:37 PM
ludelvr
May 27, 2002 03:56 PM
