Need help,wastegate doesnt sit flush with the mani.
Old Apr 7, 2005 | 08:01 PM
Civicman86's Avatar
Default Need help,wastegate doesnt sit flush with the mani.
OK I plan on installing tomorrow but have one quick question. I test fitted the wastegate on the manifold and it doesnt sit flush. The wasgate kinda pokes out at the bottom. See attached pics. Do I just need a gasket? Other alternatives
Modified by Civicman86 at 9:14 PM 4/7/2005
Old Apr 7, 2005 | 08:02 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Need help,wastegate doesnt sit flush with the mani. (Civicman86)
take something and gently tap the fire ring down flush... itll go
Old Apr 7, 2005 | 08:03 PM
Evanmb44's Avatar
it will seat fine once you tighten the bolts down
Old Apr 7, 2005 | 08:10 PM
TurboTagTeam's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turboaddict &raquo;</TD></TR><TR><TD CLASS="quote">it will seat fine once you tighten the bolts down</TD></TR></TABLE>
mine was same way
Old Apr 7, 2005 | 08:13 PM
m R g S r's Avatar
Default Re: (Turboaddict)
isn't it supposed to actually sit a little higher than the mating surface? i know mine did until i put alotta pressure on it (aka, tightened bolts)
Old Apr 7, 2005 | 08:14 PM
Civicman86's Avatar
Default Re: (m R g S r)
OK cool guys! You all are the greatest
Its on like donkey kong, be looking for after pics tomorrow. Here is a teaser
Old Apr 7, 2005 | 09:53 PM
trentepic's Avatar
i had same experince and yes jsut bolting it down will git r done, and also gimme ur manifold
OnlyHJC
Honda Motorcycles
64
May 13, 2008 04:32 PM
adubaz7
Mar 21, 2008 01:14 AM
jdm_23_eg6
Apr 30, 2005 12:32 AM
Andrew 825SM
11
Mar 17, 2004 10:46 AM
Optiks.
Sep 6, 2003 07:55 PM
