Need help with Turbo malfunction
Old Aug 8, 2004 | 04:04 PM
blues2k3's Avatar
Default Need help with Turbo malfunction
Take a look at this pic. Any comments on how this could have occurred? Thanks for your comments. BTW. the turbo is a DBB, with oil and coolant no problems with the lines.
Old Aug 8, 2004 | 04:09 PM
beepy's Avatar
Default Re: Need help with Turbo malfunction (blues2k3)
Well, it's fucked now, isn't it?
This is what happens when the bearings go to ****.
Old Aug 8, 2004 | 04:27 PM
blues2k3's Avatar
Default Re: Need help with Turbo malfunction (beepy)
this turbo had no more than 50 miles on it at low boost (6psi), which puzzles me about the bearings
Old Aug 8, 2004 | 05:33 PM
beepy's Avatar
Stone Mountain Racing?
Old Aug 8, 2004 | 06:03 PM
blues2k3's Avatar
no, I had a 4 in intake pipe with a KN filter on the turbo. When I checked the shaft it was loose and had excessive play. The damage was uniform which would justify there was no foreign object in the inlet...
Old Aug 8, 2004 | 06:19 PM
beepy's Avatar
What brand of turbo was it?
Did you have oil going into it? With that much bearing damage there should be oil everywhere.
Old Aug 8, 2004 | 11:34 PM
AkariMotorsports's Avatar
Looks as if the turbo compressor housing came loose when the fins were spinnning. I suggest you check and see if the bolts/ c-ring that holds on the compressor is loose.
Old Aug 9, 2004 | 03:40 AM
blues2k3's Avatar
Default Re: Need help with Turbo malfunction (AkariMotorsports)
I checked the compressor housing and that was secure. No oil spill and oil pressure and temp was fine. The only noticeable defect was the shaft with excessive play.
Old Aug 9, 2004 | 03:45 AM
White Smoke's Avatar
i my honda
Global Mod
THAT SUCKS
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">What brand of turbo was it?
Did you have oil going into it? With that much bearing damage there should be oil everywhere.</TD></TR></TABLE>
Ya what brand is this? It is clean as a wissle in there?? Are yo 100% sure you had a good oil source/return?? You said it was watter cooled as well?
Old Aug 9, 2004 | 05:01 AM
blues2k3's Avatar
Default Re: Need help with Turbo malfunction (si2die4)
its a garrett gt30R. The oil feed is fine. I have an oil pressure sending unit tee off from the oil feed and there was constant oil pressure at all times via pressure guage inside. Oil return is also good. I double check for any leaks or kinks. Garrett has been great with assisting me through this situation and I am switch out the turbo tomorrow.
b15ser
May 29, 2010 03:17 AM
shiftgear8000
Dec 19, 2004 09:21 PM
kj98r
May 16, 2004 03:16 PM
JChops
Nov 12, 2003 11:40 AM
